10-10-2020, 09:38 AM | #1 |
Checklist for startup after 10-month unplanned hiatus
With the pandemic going on and the coupe needing valve work, I haven't started her up since Christmas, and I didn't do anything special upon putting her away except disconnect the battery.
However, I'll need to move her in a couple of weeks and she'll run well enough to go a few miles. Can somebody verify my list of tasks prior to start?
Thanks! |
10-10-2020, 10:01 AM | #2 |
Re: Checklist for startup after 10-month unplanned hiatus
Clean the points, put some oil in the clylinders,air up the tires
10-10-2020, 10:02 AM | #3 |
10-10-2020, 10:32 AM | #4 |
Do not turn the motor over, even hand crank. Especially, if ethanol gas drain about a quart of gas out of the gas tank, let it sit and check if there is separation or water in the gas, check the sediment bowl for water. If yes drain the entire tank, leave the gas cap off and let the tank dry, then fresh gas. Also drain the carb bowl before adding fresh gas. Had water in my tank once after filling up at a station, 5 miles down the road sputtered, backfired, and finally would not start/run. When I got it going again went back to the station and a tanker was filling the underground tank - so I must have got the bottom of the underground tank. I had unpleasant words with the manager, and reported them to the State.
Check the dipstick for water, drain about a quart of oil and check for contamination. A small amount should not hurt anything, condensation in the oil should burn off if you run the car for a half hour/hour as long as the motor gets up above 160 degrees coolant temp. Contaminated gas can cause a lot of extra effort. |
10-10-2020, 01:12 PM | #5 |
After mine sat all winter all I ever did was re-hook the battery, turn on the gas, choke and start it. FWIW
Paul in CT |
10-10-2020, 01:17 PM | #6 |
10-10-2020, 04:07 PM | #7 |
Not gonna change the fluids right now since I just need to run it briefly and then it'll be back in the garage for valve inspection and a new HC head. But I will check the gas and add some MMO in each cylinder. Thanks
10-10-2020, 04:08 PM | #8 |
It only sat 10 months, not much needs to be done provided it was put away properly. I maybe would remove the plugs & clean them, check fluids, spin the engine over a few revolutions and replace the plugs then give it a start.
10-10-2020, 04:11 PM | #9 |
Guess it depends what "properly" means. I certainly didn't think at the time that I was putting it up for 10 months or I'd have put stabilizer in the gas at the very least. Temperature swings should have been relatively mild. I'm primarily concerned about the missing lubrication layer on the moving parts.
10-10-2020, 05:05 PM | #10 | |
10-10-2020, 05:35 PM | #11 | |
Many years ago, I pulled a Model A out of a barn in Up-State New York. Had been in storage since the end of WWII, about 35 years. New gas, battery, and water. Air in tires. Car started right up. Clutch was rusted to fly wheel. Car is still running fine. Enjoy. |
10-10-2020, 05:44 PM | #12 |
30closed covered it.
I have torn down too many engines that sat a long time, we’re started up on the old gas and then we’re found seized the next day. Including my F1. Drain the tank n add some new gas. I never disconnect the batteries but I won’t say anything bad about people who do. |
10-10-2020, 05:56 PM | #13 |
I disconnected the battery to prevent my kids leaving the lights on during one of their occasional make-believe driving games.
10-10-2020, 07:40 PM | #14 |
My grandfather had a 53 ford truck, us kids where playing in it and someone in the cab pushed a shiny chrome starter button. The ones in the bed almost ended up on the ground, one of only a few times I saw grandpa upset!
10-10-2020, 10:22 PM | #15 |
So it has sat for 10 months. To me that is not an especially long time.
I've opened up quite a few engines (Model A and others) that have sat much longer and they still have a good layer of oil on the moving parts. It takes a long time for oil to dry up. I'm assuming the car was in an enclosed space protected from the weather. Check the fluids and if you want put a squirt of oil in each cylinder, spin it over a few times while the plugs are still out. After that fire it up and go.
Dave / Lincoln Nebraska |
10-11-2020, 07:44 AM | #16 |
Thanks everyone for the good advice in this thread.
10-11-2020, 08:36 AM | #17 |
WHN-
You were very lucky nothing ugly got inside that engine to foul things up. Conventional wisdom is to at least drop the pan and have a look before turning over after such long storage. "your results may (and did) vary"
our next Model A is out there in the unknown...... |
10-11-2020, 09:11 AM | #18 | |
After we started the engine and found out the clutch was rusted. We dropped rear end and pulled trans to replace clutch, pressure plate, and bearings. Also pulled head and dropped oil pan. Everything was fine. Valves were a little loud. MMO fixed that within 100 miles. Compression all in the mid 60’s. I learned many years ago that you can over think a lot of things. These are simple cars, most of the time any perceived problem has a simple fix. Enjoy. |
10-11-2020, 09:41 AM | #19 |
Have you looked at the insides of the carburetor?
When my car was sitting for an extended period (without running the carburetor dry beforehand), it was not a pretty sight afterwards. |
