Old 07-15-2020, 11:07 PM   #1
bdtutton
Default Best 6V battery
It has been a long time since I purchased a 6V battery and my car and tractor are both turning over kind of slow lately. I was wondering what battery brand people are most happy with. I am OK spending a little more to get something that lasts a long time. I have a 6V Die Hard gold in my 1940 Ford 9N that is 12 years old so I appreciate things that last for a while.
Any recommendations ???
bdtutton is offline   Reply With Quote
Old 07-16-2020, 03:49 AM   #2
Wick
Wick's Avatar
Default Re: Best 6V battery
I use a Napa 6v about $98-104.00 That batter can sit for a year and still start the A with no problems.
Wick is offline   Reply With Quote
Old 07-16-2020, 06:37 AM   #3
1931 flamingo
1931 flamingo's Avatar
Before you invest in a new battery, clean ALL the connections.
As Wick says I'm also using a NAPA battery.
Paul in CT
Old 07-16-2020, 08:00 AM   #4
30 Closed Cab PU
I with 1931 flamingo, clean the starter and battery connections.
Inspect battery cables.
If not present, add an additional cable between the battery frame connection to the Bell Housing.
Load test your battery - https://www.harborfreight.com/100a-6...ter-61747.html
Check your battery electrolyte level, charge with a smart charger - https://no.co/genius5 or https://www.amazon.com/NOCO-G750-Adv.../dp/B004LX3AS6. teh 750 ma will work , just takes a lot longer.
Old 07-16-2020, 08:14 AM   #5
30 Closed Cab PU
I use Farm and Fleet batteries but take care of them, last me 4 or more years. Check the electrolyte levels every few months, put a NoCo 750MA smart charger/maintainer on them every month for few days in the Winter.
Have had good luck with the 5 amp NoCo above restoring a couple of my kids batteries - one where the battery hardly would crank the car, electrolyte level had dropped, and a motor cycle battery that had not been used for over 2 years. Brought them back to close to like new.
Old 07-16-2020, 08:59 AM   #6
Purdy Swoft
Purdy Swoft's Avatar
I always prefered Delco six volt batteries when I could find them . I now mostly use twelve volt batteries that I can pick at Walmart . I don't have to answer any questions about what automobile that the battery is for . Usually if you admit that any part is for a model A Ford , the answer will be that they don't have one . I can pick the battery that I want off the shelf without problems at Walmart . A twelve volt conversion is very simple .
Old 07-16-2020, 09:09 AM   #7
37 Coupe
37 Coupe's Avatar
Optima Red Top,nothing better.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 07-16-2020, 09:30 AM   #8
uncle buck
uncle buck's Avatar
Optima 6volt available at your local NAPA # N996VRED . I've had perfect performance with mine.
uncle buck is online now   Reply With Quote
Old 07-16-2020, 09:41 AM   #9
Robert/Texas
Robert/Texas's Avatar
I couldn't agree more about Optima batteries. My cars often sit for months without tenders and when I check their voltage they are always at 6.2 or 6.3 volts. I don't need to top them off with water and they don't corrode anything. Two are laying on their sides. As for cost, my experience with them is that they last about 12 years so they save me a money.
Robert/Texas is offline   Reply With Quote
Old 07-16-2020, 10:53 AM   #10
ryanheacox
ryanheacox's Avatar
Just replaced an Interstate that was 8 years old with a NAPA. That old Interstate replaced an 8 year old Exide. Those two old batteries were in a completely stock charging system, never sat on maintainers and only got jumped occasionally after long periods of sitting. I've since upgraded the generator with one of Tom Wessenbergs EVRs. I imagine that should gain me another year or two out of this new battery.
I guess what I'm getting at is that most conventional 6V batteries seem to be just as good as each other (hell, they probably all come out of the same factory with different labels).
Optima might be a good route but if you only get 12 years out of them I couldn't justify almost double the price for an extra 2-4 years of life.
Old 07-16-2020, 12:49 PM   #11
Kurt in NJ
Kurt in NJ's Avatar
I got 16 years out of optima, replaced it with another, was 120$ shipped, a friend has been using a optima that I found in the trunk of a junk car--- it's over 20 years old by the date code
Old 07-16-2020, 01:38 PM   #12
SoCal_Alden
SoCal_Alden's Avatar
I've been using Napa 7244 batteries for years - as previously stated - they last for a long time and perform very well.
SoCal_Alden is offline   Reply With Quote
Old 07-16-2020, 04:38 PM   #13
Chris in WNC
Chris in WNC's Avatar
I've had good luck with both O'Reillys and Tractor Supply......
our next Model A is out there in the unknown......
Chris in WNC is offline   Reply With Quote
Old 07-16-2020, 05:58 PM   #14
d.
I'll add my vote for the Optima 6v.
I've got 6 years on mine with the occasional battery tender for a few days and I get 6.5v. or better readings...plenty of juice to kick it over.
You cannot ignore the easiest best practice of using proper 1 or 2 gage cables with clean contact surfaces.
> the added ground cable from frame mount to transmission top or flywheel housing bolt is also highly recommended.
d. is offline   Reply With Quote
Old 07-16-2020, 09:38 PM   #15
M2M
M2M's Avatar
Thumbs up Re: Best 6V battery
Optima 6V yellow top
M2M is offline   Reply With Quote
Old 07-16-2020, 10:19 PM   #16
gz
gz's Avatar
I have two 6V Optima's that are currently in use and are both 10++ years old.
I have never seen a 6V Yellow Top Optima before. More cranking amps or ?
gz is offline   Reply With Quote
Old 07-16-2020, 10:30 PM   #17
M2M
M2M's Avatar
6V yellow is available in UK and Europe. The yellow CCA is a bit less at 765 but capacity is more at 55Ah compared to 50Ah for the red top. Wish they had a 6v blue top
Old 07-16-2020, 10:41 PM   #18
Synchro909
Synchro909's Avatar
When I took delivery of my CCPU, I found it had a red top Optima battery in it. Nice surprise!
I have no idea how old it is but from the time it was delivered to a friend in Arizona who sent it on to me to when I saw it, 18 months had passed. It started the engine without hesitation.
NICE!
Old 07-17-2020, 03:58 AM   #19
chrs1961815
chrs1961815's Avatar
Whatever battery you choose, make sure the tag on it has a fairly recent date on it. The older the battery is, the more likely there is something wrong with it for several reasons.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 07-17-2020, 08:02 AM   #20
chl
chl's Avatar
Replaced my optima this spring,it died after 5 years. went back to a conventional
battery and find it performs better.
chl is offline   Reply With Quote
