03-22-2016, 09:06 PM | #21 |
Location: Barren windswept mountain somewhere in bleak Northeastern Pennsylvania
Re: Zenith carburetors
Purchased the Marvel carb that's on my 31' Tudor off eBay a few weeks ago from a guy in Texas for $175. He sells both Tillotson and Marvel "re-manufactured" carburetors with free Priority Mail shipping. Just looked and he presently has no Marvels offered. Those rebuilt Marvel carburetors apparently sell like hot cakes. The night that I bought one, he sold three just before my purchase. With that overhauled as new Marvel Schebler carb, the 85 year old Ford just sits there now at idle percolating away so smoothly.
Below is a link to a Marvel carburetor being now offered by this mentioned eBay seller. http://www.ebay.com/itm/Marvel-Scheb...AAAOSwBnVW8qaW Last edited by Capt Quahog; 03-23-2016 at 12:17 PM. |
03-22-2016, 09:28 PM | #22 |
I run a high boy on my Marvel
03-23-2016, 01:56 PM | #23 |
I'd have to dig out (It is in one of my swap meet totes.) my air maze to test, but the O.D. of the air inlet is 1 3/4 inches.
03-23-2016, 02:21 PM | #24 |
I dug out my zenith. An Air Maze should fit. The air inlets are the same size as a zenith. However I don't run an air filter. My engine just has to last as long as I do!
03-23-2016, 02:52 PM | #25 |
So....is it recommended to leave a Marvel, aluminum finish, or paint it clear....or black?
Thank you.
Brian French; 1930 Briggs Town Sedan |
03-25-2016, 09:59 AM | #26 | |
03-25-2016, 10:27 AM | #27 |
Float set too high
07-05-2016, 11:42 AM | #28 |
I just installed a marvel I bought off eBay from the guy in Texas. (my second purchase from him, great to deal with) My car runs better than it ever has.
07-05-2016, 03:06 PM | #29 | |
Location: Here I am in front of Todd's Grocery in 1931 selling Grit newspapers
"Bullshit and Brilliance Comes with Age and Experience" "Hey Lady, ya wanna buy a Grit?" "If you don't learn to laugh at trouble, you won't have anything to laugh at when you're old" Will Rogers |
07-05-2016, 07:28 PM | #30 |
Send me you unwanted Zeniths, I will take them all day long and if properly built are the best for the model A...
07-05-2016, 07:55 PM | #31 |
For those who rebuild carbs, is there a big difference between the flot design of a Zenith vs a Marvel?
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
07-06-2016, 01:20 PM | #32 |
We used a KNOWN, GOOD Zeinth for the drive from Illinois to Colorado and back. No problems and we were having so much fun I never got around to changing in a newly rebuilt, beautiful, Zeinth with flowed jets that made the ride in bubble wrap. I didn't trust my workmanship for so long a drive. Last night I installed it ...
... What a sweet, smooth idle. Hardly needed any adjustment. And it pulled great all the way to 60 mph in OD. Back in the garage I did the finger-sniff test. Carb was completely dry. No drips. No. I don't want to rebuild carbs for $$$. But I do love that efficient Henry Ford design with just one bolt holding it together! Sweetness! |
07-06-2016, 01:47 PM | #33 |
With all these posts that talk about Henry's designed Zenith carbs, am I to understand that all Model A's came off the line with one of his Zenith carbs attached and not another carb?????????
07-06-2016, 04:57 PM | #34 |
"Tom Endy", when you are on this forum long enough, you know who to listen too! Follow his procedures, skip nothing, and smile when your "A" passes a modern car!!!
http://MODELABASICS.com/ How Things Work on a Model "A" Ford Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles. |
07-06-2016, 05:13 PM | #35 |
First I heard of this................... The fuel line: It is prudent to wrap both ferrule ends of the fuel lines with white Teflon tape. Do not wrap the tape around the threads, as this is not where it seals. The seal is at the ferrules. The ferrules after much use will become deformed and wont seal off inside the fittings at the carburetor and at the firewall fitting. The tape will ensure a proper seal. Do not allow the tape to get over the ends of the fuel line. See photo below.
07-06-2016, 05:52 PM | #36 |
07-06-2016, 06:23 PM | #37 |
As it's said...."proof is in the pudding"!!!
Thanks
07-06-2016, 06:57 PM | #38 | |
I know that a lot of guys like to use the teflon tape but I have found small slivers of that tape in places it shouldn't be. It can plug up small orifices in the carb or in valves, anyplace you don't want it to be. I won't use it on anything but household plumbing and even there I want to use pipe dope for the sealing and lubrication benefits. Even using teflon tape around the ferrules in a compression fitting can create problems. Here is proof inside a solenoid valve. Don't do it. |
