04-16-2015, 08:57 AM | #1 |
Barrett B-75BS True-Arc Brake Shoe Grinder
In my quest to do the best brake job on my A and my 32 I have just picked up a brake shoe grinder. It requires an 8 1/4" diameter abrasive disc, Cat. # 99A-36, part number 80-1240-1.
My sales rep has no idea what I am talking about, so, experts, what do you use as a substitute and where to you get it? Thanks for your suggestions. Ted |
04-16-2015, 11:07 AM | #2 |
Re: Barrett B-75BS True-Arc Brake Shoe Grinder
04-16-2015, 12:12 PM | #3 |
Thanks Bob, that looks like a good resource. I hope to hear what works for others in terms of grade,Grit, open/ closed, cloth or paper backed. Ted
04-16-2015, 01:04 PM | #4 |
Yes, look at woodshop supply companies where they sell orbital disc sanders. My brake grinder spins at a high RPM, and we generally do not need to take off much material so an 80 - 120 grit is fine.
04-16-2015, 04:51 PM | #5 |
I purchased a vintage brake shoe grinder from the local NAPA dealer - a different brand than yours, and parts were no longer available. I needed abrasive belts for mine and found a good source for shop equipment at: Goodson.com
Possibly they can help you too. They were very good to work with. John |
04-16-2015, 08:03 PM | #6 |
04-16-2015, 09:30 PM | #7 |
Thanks Brent, John and Kurt. I was thinking with the part number as A-36, that it might refer to the coarseness. Will keep looking.
04-16-2015, 09:38 PM | #8 | |
http://www.abarnyard.com/ |
04-17-2015, 07:53 AM | #9 |
Thanks Marco. I will see what I can find. Now to find a drum lathe with the 11/16" spindle.
04-17-2015, 12:39 PM | #10 |
40 grit seems to be the most popular for brake shoe grinding sleeves that Goodson sells, so that narrows my search. Now is that open or closed?
04-18-2015, 11:13 PM | #11 |
motordoc, There is presently a Barrett 11/16-1 inch arbor on EBay. $99.00 Search under Ammco. Is your brake lathe a Barrett?
04-19-2015, 04:02 PM | #12 |
KR500, I don't have a brake lathe yet. I am just now starting my search. Ted
05-03-2015, 08:01 AM | #13 |
An update on the abrasive disc, I bought a Norton Metalite R228 PSA Disc, Cotton backing, Pressure sensitive adhesive, aluminum oxide, 24" diameter, 40 grit for $7.80 plus shipping on Amazon. I cut out an 8 1/4" disc and put it on. Works great and I can get a few more discs out of it if needed.
Now I just need to figure out why it is not grinding a true arc. I also just bought an Ammco 4000 drum lathe with all the tooling. It does a beautiful job turning front drums. I have the Ammco 9708 11/16" Arbor kit coming this week. Can't wait to see how it works turning rear drums. Ted |
05-03-2015, 11:27 AM | #14 |
Do you have the instructions for the grinder?
Bob |
05-03-2015, 11:51 AM | #15 |
