Old 04-28-2019, 03:04 AM   #1
chrs1961815
chrs1961815's Avatar
Default Old Headlight Bar Repair
What do you think of this?
chrs1961815 is offline   Reply With Quote
Old 04-28-2019, 05:22 AM   #2
Joe K
Joe K's Avatar
Default Re: Old Headlight Bar Repair
Seems nicely done. Doubt its factory - although I have seen some braze repairs done on machine castings which would have had to have been factory.
Paint it up - use it. Part of history now.
Joe K
Shudda kept the horse.
Joe K is offline   Reply With Quote
Old 04-28-2019, 09:08 AM   #3
BILL WILLIAMSON
BILL WILLIAMSON's Avatar
HISTORY NOW????---Spare me!!! It's somebodies' quick BRAZING job!!
Bill W.
"THE ASSISTANT GURU OF STUFF"
Old 04-28-2019, 09:12 AM   #4
Jwilli
Jwilli's Avatar
Bill W.
Good morning Bill, have a great day.
Jwilli is offline   Reply With Quote
Old 04-28-2019, 01:16 PM   #5
chrs1961815
Joe K
I didn't even notice it until I blasted it. Part of an accident you think? Needs to be grinded and filed a bit in my opinion.
Old 04-28-2019, 02:22 PM   #6
BillCNC
BillCNC's Avatar
Yes, and pretty decent job as well. If it's straight, it's better than a solid one that looks like a re-straightened Top Raman Noodle.
BillCNC is offline   Reply With Quote
Old 04-28-2019, 07:50 PM   #7
Chuck Sea/Tac
Chuck Sea/Tac's Avatar
I was under the idea that brazed parts don’t accept paint well?
Old 04-28-2019, 08:14 PM   #8
Joe K
Joe K's Avatar
Its all in the surface prep. Sharp grit, surface roughness profile and paint will be fine.
Or at least you won't have to worry about the part rusting underneath and the paint lifting?
Joe K
Old 04-28-2019, 09:21 PM   #9
chrs1961815
Joe K
Hopefully. Brazing has to be pretty old so hopefully they didn't braze over any rust (if they weren't an idiot). It is a nice bar all together - no pitting besides the spots where it bolts to the fenders and it is not bent (at least I can't tell). Follow up question - there is a small hole in the middle of the underside of the bar. Is this factory or was it drilled?
Old 04-28-2019, 11:02 PM   #10
Steve Plucker
I have the same holes...Must be factory.
Pluck
Old 04-29-2019, 12:03 AM   #11
Tom Wesenberg
Tom Wesenberg's Avatar
Yes, they holes are factory.
Old 04-29-2019, 09:33 AM   #12
Ed in Maine
I often look at things like this from the point of view of "is it a safety related issue?" In this case I don't think so and if it breaks on a tour your could wire it up and get home. I would paint it and use it. Ed
Ed in Maine is offline   Reply With Quote
Old 04-29-2019, 11:19 AM   #13
Purdy Swoft
Purdy Swoft's Avatar
If flux or fluxed brazing rods are used , there usually will be paint problems . If the part is ground down to clean metal with no flux used , the paint can hold up ok . I mostly avoid the use of brazing . I would have welded the part instead .
