02-10-2019, 11:01 AM | #1 |
30-31 windshield vs 32
How close is a 30/31 windshield to a 32? Also anyone making a 32 windshield that is like the original i.e.: a bit more rounded than the repops I see out there?
A man should do what he thinks best! "The Duke" |
02-10-2019, 11:20 AM | #2 |
Re: 30-31 windshield vs 32
If you mean for a phaeton/roadster, not even close given that your concern seems to the cross section of the frame.
02-10-2019, 11:25 AM | #3 |
The only model A windsheild that fits a 32 in shape and size is the truck. And it fits 33 34 but the bottom of the frame on a model A has a lip that has to be cut off
Nothing else is the same like a roadster ect |
02-10-2019, 12:23 PM | #4 |
Yes the cross section on the repops do not look close to an original.
02-10-2019, 02:05 PM | #5 |
The ones from NC Industries in Pennsylvania are very good and a cut above the others.
02-10-2019, 04:05 PM | #6 |
As noted the 1932(-34) closed pickup has a similar tubing section to the 1926-31 closed car, however the shape and dimensions are very different. Everything else is not close. |
