Old 11-16-2012, 02:36 AM   #1
46Chief
46Chief's Avatar
Default Model A door tops
My 30 coupe has two different types of door tops. One has a wood strip held on by 3 screws and one has a metal top that looks like it is seamed and folded together (making glass replacement difficult) can someone please enlighten me as to what year doors I have on my coupe? Many thanks.
46Chief is offline   Reply With Quote
Old 11-16-2012, 08:59 AM   #2
Farrell In Vancouver
Farrell In Vancouver's Avatar
Default Re: Model A door tops
Maybe post some pix 46Chief, I have not seen coupe doors with a wooden top, only the metal "caps" held on with three screws.
Farrell In Vancouver is offline   Reply With Quote
Old 11-16-2012, 10:12 AM   #3
Marco Tahtaras
Marco Tahtaras's Avatar
All Coupe and Tudor models had metal caps on the top of the doors. As noted they were held on with three screws. On each of the two corners that face the inside of the car there is what appears to be a countersunk rivet. Those are actually just pins that are part of the cap and release from the door when the cap is tilted off.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 11-16-2012, 11:03 AM   #4
JoeWay
JoeWay's Avatar
Maybe the original cap was lost or damaged, and the previous owner fabricated a wooden replacement?
If a job like this had been done by someone like my Dad, it would look and work as if it was a factory part.
Joe
1929 Tudor
since 1962
Feather River A's
JoeWay is offline   Reply With Quote
Old 11-16-2012, 12:11 PM   #5
Tom Wesenberg
Tom Wesenberg's Avatar
If you need the door tops I'm sure my friend has some.
Old 11-16-2012, 09:47 PM   #6
Drive Shaft Dave
I bought one from Berts a couple of years ago, used original.
Drive Shaft Dave is offline   Reply With Quote
