Old 04-18-2021, 06:30 PM   #1
Steve Rinaldo
Default modern point set follow-up
The reason that I posted earlier was that after a drive yesterday I noticed that the the car did have its normal power. and found that the spark was weak. I took the distributor cap and body off and found that that point gap was was quite large.
The points I was using was an Echlin CS 755 set. I found that the spring on the contact set was quite strong and seemed to to push the plate out of position causing the point gap to increase.
I searched the NAPA website and found there a several sets that work for these Ford V/8 engines. My local NAPA had the three different sets sent to the store so I could compare them. They were the, CS751,CS755 and the heavy duty set. What I found out was that the CS755 spring was quite strong and the tension on the heavy duty set was really strong. I went with the CS 751 {standard set}. I think this will solve my problem, if not I'll let you know. Some side info the screw size used on the point plat are 8-32. Steve
Steve Rinaldo is offline   Reply With Quote
Old 04-18-2021, 11:15 PM   #2
Russ/40
Russ/40's Avatar
Default Re: modern point set follow-up
Sounds like the upper bushing in your distributor is worn. Point spring tension should not affect the gap in any way. Could be the upper plate is worn as well.
Old 04-19-2021, 05:48 PM   #3
Rob Doe
Nice thread. Timing is good for my current issues.
Rob Doe is offline   Reply With Quote
Old 04-19-2021, 06:02 PM   #4
California Travieso
Send a message via Yahoo to California Travieso
It would have been more consistent to update your original thread instead of starting a new one.
David Serrano
California Travieso is offline   Reply With Quote
Old 04-20-2021, 06:22 AM   #5
Bob Bidonde
Bob Bidonde's Avatar
This may be your problem:
File Type: jpg Upper Plate Fit In Distributor Casting.jpg (52.0 KB, 53 views)
Bob Bidonde
Old 04-20-2021, 06:28 AM   #6
Steve Rinaldo
Thanks for the help. I installed the CS751 points. gapped them to .020. Then ran the engine and it ran great. I now have a blue spark over 1/2 inch long. I'm not sure what caused or fixed the problem.
Old 04-20-2021, 06:45 AM   #7
Big hammer
A better ground path ?!
get a bigger hammer tap done
Big hammer is online now   Reply With Quote
Old 04-20-2021, 07:20 AM   #8
Patrick L.
Patrick L.'s Avatar
You made a pun ! Actually 2 of them !
