Old 03-28-2021, 05:35 AM   #1
nathanmac
Default Dual exhaust on right hand drive 1940 pickup
Would anyone have a photo of their manifold/headers running dual exhaust on a right hand drive 37-41? Have tried searching old threads but couldn't see any pictures.
I don't have my pickup here but remembered today I had these manifolds from when my motor was in a stationary fire pump. Hoping I might be able to modify the rhs to be able to run the front pipe past the steering box and starter.
Any photos or help appreciated.
nathanmac is offline   Reply With Quote
Old 03-28-2021, 07:07 AM   #2
tub1
tub1's Avatar
Default Re: Dual exhaust on right hand drive 1940 pickup
get your self a set of pilot manifold and you will be good to go
tub1 is offline   Reply With Quote
Old 03-28-2021, 04:13 PM   #3
nathanmac
Thinking they might be a bit hard to find too, and maybe more expensive than working with what I have. I'm keen to see a photo of how others have run their front pipes to see where they track through all the clutter.
Old 03-28-2021, 04:52 PM   #4
tubman
tubman's Avatar
I have to say it. Those are unusual looking manifolds. I imagine they are cast iron, but maybe not. If you can't find the Pilot manifolds, get some nickel rod, a bucket of sand, some charcoal, insulated blankets, and have at it. If they are steel tube, you're home free. They look like you could make them into something cool!
Old 03-28-2021, 04:58 PM   #5
G.M.
On all the 39 Fords I put duals on over the past 65 years I
usd a BIG hole saw the size of the height of the oval opening
and elongated the hole towards the engine. G.M.
www.fordcollector.com
Old 03-28-2021, 06:51 PM   #6
KiWinUS
KiWinUS's Avatar
Oh dear. From the legendary home of Burt. So for sure you know Darrel the part time blues brother & Fraser. All great friends of mine. Not including John Smeeeeerth. 2 Forde rd.
I believe someone in Invers can help you.
KiWinUS is online now   Reply With Quote
Old 03-28-2021, 07:24 PM   #7
nathanmac
Hi, yes I haven't gotten to asking anyone local yet, but hoped I might have seen some photos of different solutions for rhd. And when I remembered the manifolds I had stashed away in the shed last night I thought I'd post a pic and ask.
I'm not sure if these manifolds are the original parts for the stationary fire pump but they look well made and might be a shortcut to success for me as they're welded steel pipe.
Old 03-28-2021, 11:49 PM   #8
swoopNZ
MEMBER EMERITUS
Try Bari Fitzgerald.
swoopNZ is offline   Reply With Quote
Old 03-29-2021, 01:29 AM   #9
FlatheadEric
FlatheadEric's Avatar
Hey Nathanmac,
I was doing this exact thing on my RHD '37 today. Finished the RHS today and half finished the LHS.
I used an 8BA manifold on the RHS that has the exhaust outlet at the rear of the manifold and allows the exhaust pipe to avoid the steering box and starter. The pipe leaves the 8BA manifold and drops at fairly tight angle down through the elongated hole in the diagonal chassis member directly behind the steering box, and away to the rear.
I am working in Tauranga tomorrow but should be able to do some pictures tomorrow night.
FlatheadEric is offline   Reply With Quote
Old 03-29-2021, 01:37 AM   #10
nathanmac
Hey yes I have to see him about something else once my brakes are done - just having a wee burst of tidying things up on the pickup and need to pick his brain a little.
Old 03-29-2021, 01:42 AM   #11
nathanmac
Originally Posted by FlatheadEric View Post
Hey Nathanmac,
That would be great, thanks Eric. I just haven't spent enough time around V8s to know how it's best done. I need to mentally prepare myself for these things nowadays so pics would be fantastic. And an 8BA manifold should be a bit easier to come by?
How close to the starter does it run - any heat shields required around it or the master cylinder?
Much appreciated.
Old 03-29-2021, 01:46 AM   #12
FlatheadEric
No heat shields required as it clears the starter and steering box by plenty.
Not sure about the master cylinder as my '37 is still running cable brakes.
Old 03-29-2021, 01:52 AM   #13
nathanmac
Ahh true. Thanks, look forward to the photos when they come through, will start searching for the right manifold.
Old 03-30-2021, 12:27 AM   #14
FlatheadEric
Hey Nathan,
Here is my amateur attempt at the RHS of a RHD dual exhaust. I have only shown the RHS as the LHS is straight forward with no obstructions to talk about. This was only done yesterday so has not been tidied up as yet.
I have brought the pipe as far to the outside of the elongated chassis hole as practical so as to give the brake pedal arm as much travel as possible. If the brake pedal arm was to travel down far enough to hit the pipe then there would be a serious issue with the brake adjustment and would require attention.
I plan on just blanking off the front end of the 8BA manifold where I think the automatic choke sensor would have been.
Old 03-30-2021, 05:37 AM   #15
nathanmac
Outstanding, thanks Eric. That's exactly what I needed to see. Now on the hunt for one of those manifolds...
Much appreciated.
