05-11-2015, 09:44 AM | #1 |
Headlght draw?
When driving my car at highway speeds with the lights on low beam ,I have a negative draw on the amp gauge of about 4 amps ( if it is accurate). I s this normal? I have original style head lamp bulbs. Generator charge fine also. Sometimes up to 10 amps if battery is low.
thanks |
05-11-2015, 09:52 AM | #2 |
Re: Headlght draw?
yes
05-11-2015, 10:27 AM | #3 |
Re: Headlght draw?
That's why folks would drive country roads, on MOON LIT NIGHTS, with only the park lights on.
Bill W.
05-11-2015, 04:08 PM | #4 |
Re: Headlght draw?
So, I take it that it is normal. Thanks Steve
05-11-2015, 04:09 PM | #5 |
Re: Headlght draw?
if you do alot of night driving you can adjust the 3rd brush but the best bet for all around use is installing an EVR. electronic voltage regulator.. they are hidden
05-11-2015, 04:35 PM | #6 |
Re: Headlght draw?
Less amps drawing and being able to use lighter cable and save weight and money . OHMS Law. amps = watts X volts. If your low beam is 35 watts and tail light is 6 and dash light is 3 ?, that is 79 watts plus ignition running at the same time. Divide all this by 6 and that will give you amps with engine not running, and only approximately, because a static battery could be anywhere from 6.8 down in volts. Running, you could have 7 .2 volts, so a good system should draw about 11 amps plus ignition with lights on and running. Try blowing the horn at night and watch the amp gauge. |
05-12-2015, 07:37 AM | #7 |
Re: Headlght draw?
As mentioned above, Ohm's law you should see a drop when you step on the brakes. Example, after I installed a center LED brake light, I saw little more drop as expected.
-Mike Late 31' Ford Model A Tudor, Miss Daisy I don't work on cars --I'm learning about my Model A. Cleveland, Ohio |
05-12-2015, 07:49 AM | #8 |
Re: Headlght draw?
not to be picky...but ..... amps = watts / volts.
(which you verbally described correctly) |
05-12-2015, 07:53 AM | #9 |
Re: Headlght draw?
As I recall, my brother is running the direct replacement halogen bulbs and a generator.
His generator is putting out a measured 20 amps by a modern amp meter. His battery life is running about 5 to 10 years per battery. He is aware of his car and charging. On long drives he will run his headlights to not over charge his battery. He has a band voltage regulator, but has not seen enough need to put it on the car. Keep in mind the battery is a storage device. It is ok for there to be a negative charge rate for a while, the battery can handle it quite fine. The high amp negative bursts for the horn are fine too, that is why there is a battery. The system works fine if you have good wiring with clean connections and no frayed wires. Alternators and 12 volts will not make a more reliable or better car. Seems those cars have more issues. |
05-12-2015, 08:29 AM | #10 |
Re: Headlght draw?
Just to be correct and it's a cold gray day....
Watts = Volts times Current times Cosine Angle between them. For resistive load (headlights) the angle is 0 degrees so the watts is just volts times amps. Marc |
05-12-2015, 04:59 PM | #11 |
Re: Headlght draw?
