Old 09-17-2021, 04:34 PM   #1
scott_vt
scott_vt's Avatar
Default Custom Avatar Help
Im hoping someone can walk me through loading a custom avatar. Any help is appreciated !
Thanks,
scotty
scott_vt is offline   Reply With Quote
Old 09-17-2021, 04:40 PM   #2
Ivan in southeast va.
Ivan in southeast va.'s Avatar
Default Re: Custom Avatar Help
Tap User CP at the top of the page and then go down the list on the left side of the page and tap edit avatar.
Ivan in southeast va. is offline   Reply With Quote
Old 09-17-2021, 04:44 PM   #3
And be sure to have a picture available on your phone or computer to select from. Just play with it, you will figure it out.
Old 09-17-2021, 05:46 PM   #4
dankurth
I tried, I failed. I'll keep at it.
dankurth is offline   Reply With Quote
Old 09-17-2021, 06:03 PM   #5
Did you use option 2 where it wants you to choose a picture from your device? Might also need to reset the fields or download the picture.
Old 09-17-2021, 07:11 PM   #6
Mister Moose
Mister Moose's Avatar
Tell us at what step it hangs up, and what you see on the screen. Or I can PM you my email, send me the photo and your password, and I'll do it for you.
Mister Moose is offline   Reply With Quote
Old 09-18-2021, 07:01 AM   #7
scott_vt
scott_vt's Avatar
Good Morning,
When I try to down load the photo I get the message "Invalid File". ??
Maybe the file size is too large, although I have tried to make the file smaller!
Possibly the file extension is not being accepted ? My file extension is .eml ?? How do I change that to an extension that is accepted ??
Scotty
Old 09-18-2021, 07:27 AM   #8
nkaminar
nkaminar's Avatar
I don't know what application you are using but most have a "Save As" option where you can change the file type. If that application does not have this option, try opening it up in another application. Without looking, I would say the site is most likely looking for .pdf or .jpg.
Old 09-18-2021, 07:49 AM   #9
scott_vt
scott_vt's Avatar
Thanks guys, it looks like I got it !
scotty
