04-05-2021, 11:55 AM | #21 |
Re: Hood supports
Here is a photo of some hood supports that a member of our club fabricated. Just rotate the clip up to support the open hood, and rotate the clip down when you close the hood.
I like them because you do not bang your head on the supports that bolt on the radiator support rods.
1931 160B & 1931 68B If you don't have time to do it right the 1st time, how do you have time to do it the 2nd time? |
04-06-2021, 07:51 PM | #22 |
Re: Hood supports
I have the type shown in post #8 above and I’m not sure I’d want to do without. Hood is stable and secure when open and as others have noted, allows access to both sides of the engine.
Sent from my iPhone using Tapatalk |
04-06-2021, 08:49 PM | #23 |
Re: Hood supports
Two different solutions for Hood Supports. |
04-06-2021, 09:35 PM | #24 |
Re: Hood supports
Does anyone else have their hood rub on the quail tail?
04-07-2021, 04:18 AM | #25 |
Re: Hood supports
04-07-2021, 05:59 AM | #26 |
Re: Hood supports
I filed my tail 2/10 of an inch away. That is inconspicuous and the hood works well.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
04-07-2021, 07:12 AM | #27 |
Re: Hood supports
I have them on both of my Model A's . I made my own out aluminum bar stock and bent them and dipped the ends in liquid plastic to stop chipping the paint.
04-07-2021, 08:30 AM | #28 | |
Re: Hood supports
I like the simple mounting bracket from #160B and will build it again by myself.
04-07-2021, 08:43 AM | #29 |
Re: Hood supports
I slipped a bit of rubber hose around each swing arm to eliminate the rattle.
04-07-2021, 10:21 AM | #30 | |
Re: Hood supports
In inchland, 2/10~= 3/16. Anyway, how long ago did you do this? Is the plating peeling off where the edge is now exposed to weather? What about corrosion on the bare metal? Maybe painting the filed edge with a rubberized compound like that tool handle dip stuff would both seal it and protect the hood edge. Probably look pretty bad though. |
04-08-2021, 06:29 AM | #31 |
Re: Hood supports
Hi Mr. Moose,
that is right, I don't know about the inch breaks. But I think that's easier to understand than our decimal millimeter unit? - I polished the quaills edge of the filed tail end with a 'Minimot' rubber polisher. Then sealed the edge with 2 component epoxy resin. Invisible and no possibility of corrosion.
04-08-2021, 09:15 AM | #32 | |
Re: Hood supports
Most accurate is to say "This much" with thumb and forefinger, but that's tough to express in print. |
04-08-2021, 02:03 PM | #33 | |
Re: Hood supports
https://www.snydersantiqueauto.com/P...earchByKeyword
Ruth "Sometimes you really DO need to read the whole thread" |
04-08-2021, 03:52 PM | #34 |
Re: Hood supports
04-09-2021, 07:10 PM | #35 |
Re: Hood supports
I like mine, see pic in post #8, I have the same thing.
04-11-2021, 04:06 PM | #36 | |
Re: Hood supports
This morning I copied your friend and fabbed up a couple hood supports like in your picture. Easy, cheap and work great. Thanks for sharing. Last edited by Y-Blockhead; 04-11-2021 at 04:23 PM. |
04-12-2021, 03:44 PM | #37 |
Re: Hood supports
Snyder's has yet another type of hood prop. Kind of expensive tho for a piece of metal.
The Master Cylinder Enjoying life at the beach in SoCal... |
04-12-2021, 04:04 PM | #38 | |
Re: Hood supports
04-12-2021, 04:16 PM | #39 | |
Re: Hood supports
04-17-2021, 02:26 PM | #40 |
Re: Hood supports
I bought the same ones as in post#8 but I got no instructions. Not to hard to figure out how to put them on but...
Should I use the small ends or the long ones, or is it just a matter of preference. |
