05-27-2017, 11:02 PM | #1 |
Amp Guage Nut Tool
I finished up my amp guage restoration this week and needed a good way to tighten the special nuts on the back of the guage. I had seen the special tools that some folks had made, very nice but not something I could make. As I was cleaning off my workbench today I ran across a piece of Model A fuel line that I had cut up, it was the 90 degree bend.
I got my dremel tool and file out and ended up with a "low tech" tool to tighten those special nuts. It took 15 minutes to make, and worked great. |
05-27-2017, 11:41 PM | #2 |
Re: Amp Guage Nut Tool
Good work!
05-28-2017, 08:28 AM | #3 |
Dan, you're the man! Nice cheap tool. BTW, how did you make the right angle notches in the end of the gas line? Did you use a tiny tipped bit? I have used a Dremmel and RotoZIP (my favorite, as it has a nice handle on it) to dress down welds and grind metal, but trying to make a nice right angle notch is tough to do for me.
Rusty Nelson |
05-28-2017, 08:57 AM | #4 |
I use my 90 degree, pointy, Snap Ring Pliers---
One Guy ground a DEEP relief in a screwdriver tip, with a cut-off wheel, & it did quite well. You only have to tighten them every 37 YEARS!--LOL Bill W.
05-28-2017, 11:59 AM | #5 |
If I was going to do this a lot I would cut it and weld a T handle on the main shaft. |
