07-03-2021, 03:32 PM | #1 |
oil pump
Today I worked on the pump for my b engine opened up the inlet vertically not the with and increased the feed hole to 3/8 with an end mill and brazed the slots up and fitted it to the block. Next I will do the oil hole in the side of the block and the body of pump. Now the question will the pump drive from a 29-31 a engine fit the b engine? Snyders doesn't list one for the b. I didn't get one with the block just the pump and distributer.
07-03-2021, 10:15 PM | #2 |
Re: oil pump
Model A & B are the same.
Chris W. |
07-03-2021, 10:23 PM | #3 |
Re: oil pump
No they are not the housing is the same but ford changed the out let holes and the b shaft is reduced in diameter for more flow.
07-03-2021, 10:28 PM | #4 |
Re: oil pump
I read your post wrong sorry I thought you were discussing the oil pumps. Thank you for replying that the pump drives are the same that helps me out.
07-04-2021, 01:50 AM | #5 |
Re: oil pump
Lawrie |
