07-24-2021, 08:05 PM | #1 |
Valve seat cutters
Can anyone recommend a good valve seat cutter set ?
Tnanks .. |
07-25-2021, 03:05 PM | #2 |
Re: Valve seat cutters
Are you trying to grind existing valve seats like you would do for a valve job OR are you talking about installing new valve seats?
https://www.google.com/search?q=ford...hrome&ie=UTF-8 Also this: https://www.jalopyjournal.com/forum/...achine.627796/ Some flatheads used hardened valve seat inserts and later blocks did not. Will that make a difference? You can get an idea of brands on Ebay. https://www.ebay.com/sch/i.html?_fro...inder&_sacat=0 https://www.fordbarn.com/forum/showthread.php?t=82773 Last edited by 19Fordy; 07-25-2021 at 03:17 PM. |
07-25-2021, 04:05 PM | #3 |
get one of these and you will never need another tool. https://theultimatetooling.com/en/pr...-seat-grinder/
I use that grinder in my motorcycle shop and have had perfect seats ever since. |
07-25-2021, 04:50 PM | #4 |
or get a set of new way cutters
Lawrie |
07-25-2021, 07:30 PM | #5 |
I'll second the Neway cutters.
07-26-2021, 06:43 AM | #6 |
https://www.newaymfg.com/cutters
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
07-26-2021, 06:56 AM | #7 |
Neway cutters. I used an old B&D seat grinder set successfully for years, but recent issues with the quality of grinding stones had me frustrated. Bought a set of Neway cutters and will never go back to stones. They do a great job.
07-27-2021, 06:07 PM | #8 |
Just bought from neway, thanks all ..
07-27-2021, 07:24 PM | #9 |
What do youall use for a guide. Anything I've tried is pretty loose and sloppy. And, yes, I have an old accessory guide that was intended for valve seat work, but it is also sloppy.
07-27-2021, 07:42 PM | #10 |
Neway is selling me a guide that twist tight, I dont know, but Ill post a pic of it soon as I get it
07-27-2021, 08:19 PM | #11 |
Elwood, are you going to use the manual tool to turn the cutter or did you spring for the drive motor? It seems like no more than I would use it, the manual method would work for me.
07-27-2021, 08:37 PM | #12 |
I use the original flathead pilot that came in the old Black and Decker set I have. Locates in both the lifter and guide bores. Works great.
07-27-2021, 11:56 PM | #13 | |
One of my close machine shop relatives won't even consider using these things, because of the quality of the finish they produce. He swears that only a properly used stone can achieve the finish that he shoots for. So, I've become biased... I have experimented, to try and achieve the same finish that he achieves with his stones. And, that has led me to the 'pretty slow, and light', for the final finish. Just opinion, and I'm open to other thoughts and suggestions. (And, BTW, I have owned my Neway cutters since the 1970's, and have used them numerous times, for a variety of different engines.) |
07-28-2021, 07:34 AM | #14 |
I insert a guide with a retainer and spring and use a regular pilot. Michael Driskell told me he just drives in a knurled guide. Wish I had access to an accurate lathe so I could make one up.
As for finish I use a light cut for the end. Also I have never heard of a bad valve job due to finish. Even back in my inexperienced days they ran ok. Not that I'm experienced now either.
07-28-2021, 01:21 PM | #15 |
I am hooked on Neway now.. As franks mentions I use a knurled guide as a pilot. I use a cutter with a 45 on one side and a 30 on the other
07-28-2021, 03:41 PM | #16 |
I used a split guide, and a 5/16" pilot (expandable) before acquiring the proper pilot for flathead.
For a smooth finish, try a bit of soapy water for a lubricant on the seat. I've used Simple Green also. I've hand cut seats- flathead is hard to set up with Neways motor rig. I've also used a 1/2" deep socket on a drill motor. Hand power gives a better feel. Karl |
07-28-2021, 10:13 PM | #17 |
If the seats are really bad, I use the motor. Light cuts I do by hand.
07-29-2021, 07:15 PM | #18 |
Im thinking slow and easy, so im going with the hand tool, they shipped today so ill post a pic of what i get, thanks everyone for the input
07-29-2021, 07:19 PM | #19 | |
08-06-2021, 02:53 PM | #20 |
MARK! Did you get your pilot tool yet, I need to do valves on one of my flatheads.
You can't build a reputation on what you are going to do. Henry Ford Click Here: 'The Barn Find T' |
