Old 07-26-2021, 04:06 PM   #1
std1940
std1940's Avatar
Default Diamond Back Bias Ply looking radials
Looking for feedback on Diamond Back radial tires with the Bias Ply look.
I want to mount them on stock 1940 wheels.
What do I need to know?
std1940 is offline   Reply With Quote
Old 07-26-2021, 04:39 PM   #2
3Dueces
3Dueces's Avatar
Default Re: Diamond Back Bias Ply looking radials
You need to know if you can cover the check...P.S. They're worth every penny!
3Dueces is offline   Reply With Quote
Old 07-26-2021, 05:42 PM   #3
mike42
mike42's Avatar
I looked at them, but at the time they weren’t available so I went with the Cokers. It is a really big difference in ride and handling !
Mike
mike42 is online now   Reply With Quote
Old 07-26-2021, 05:51 PM   #4
deuce_roadster
deuce_roadster's Avatar
I have them on both my 40s, stock wheels. No problems. Makes the cars drive really nice. The pictures in my 40 woodie album were when I had the bias ply tires on for Concourse judging. No longer need to be point judged so I switched to radials. Put blackwalls on the 40 business coupe from the beginning.
Old 07-26-2021, 06:46 PM   #5
VeryTangled
VeryTangled's Avatar
I like 'em. Much better than bias but we knew that.
Pricey. But once bought, satisfying.
Went on my 35 wires, but I struggled.
They are packed (in a wrapper) to pull the beads together (and protect during shipping), but they had put the tire so it didn't wanna seat the bead (while inflating through the stem). I recommend unwrapping & let them relax. Or prop them open to relax them somehow (maybe some small wood sticks?).
-Jeff H
Old 07-27-2021, 08:51 AM   #6
glennpm
glennpm's Avatar
Re: "They are packed (in a wrapper) to pull the beads together (and protect during shipping), but they had put the tire so it didn't wanna seat the bead (while inflating through the stem). I recommend unwrapping & let them relax. Or prop them open to relax them somehow (maybe some small wood sticks?)."
Put them out flat in the sun to make them flexible. Heat both sides, lube the bead and they'll be a lot easier to mount. I do this all the time for motorcycle tires and the same when I've mounted car tires.
Old 07-27-2021, 08:58 AM   #7
Mart
Mart's Avatar
Put a tube in them and partially inflate it to help spread the walls out.
Mart.
Old 07-27-2021, 09:59 AM   #8
joe 1950
joe 1950's Avatar
Also a couple of large open end wrenches
joe 1950 is offline   Reply With Quote
Old 07-27-2021, 10:16 AM   #9
pistonbroke
I have them on my 46 Cadillac . I liked them so much I have a set coming as we speak for the 41 pickup to replace the brand new Cokers it came with when I bought it.
Old 07-27-2021, 11:44 AM   #10
JayChicago
JayChicago's Avatar
The avatar picture here shows DiamondBack Auburns on a ‘40. Very happy with the tires. Have had no problems. Not happy with how much I had to spend to get them.
I bought the radial tubes because didn’t trust that the rim on my original wheels would provide a clean air-tight seal.
Old 07-27-2021, 06:38 PM   #11
std1940
std1940's Avatar
What tire size did you go with?
600-16 or 650-16
Also whitewall width and did you get the beauty bar?
Thanks Tom.
Old 07-28-2021, 10:28 AM   #12
JayChicago
JayChicago's Avatar
600-16 or 650-16
Thanks Tom.
These are standard size, 600-16.
3" whitewall
What's a beauty bar? Is that a raised band on the sidewall above the whitewall? Didn't order that. Don't recall that option available when I bought in 2017.
Here is a pic that you can enlarge:
Old 07-28-2021, 11:50 AM   #13
tubman
tubman's Avatar
We called 'em "beauty rings" in Minnesota.
Old 07-28-2021, 02:33 PM   #14
std1940
std1940's Avatar
3" whitewall
Thanks for the photo I can enlarge.
That is the raised band about 5/8 wide above the whitewall.
My current byas ply tires from Coker that are Ford script has them.
Coker no longer makes Ford script tires.
I am going with the Diamond Backs that are 650-16 which was an option with the 3" plus 5/8 beauty bar whitewalls plus radial tubes as you sugested.
Attcched is my current tire with Ford script and beauty bar. Ford script is faint but on bottom right.
Thanks Tom.
File Type: jpg 281DE941-32E7-4AFA-89E6-8F7B23C6D7E8.jpg (67.8 KB, 179 views)
Old 07-29-2021, 12:07 AM   #15
lgndlt5
Folks just mounted new diamond back Auburns as noted difficulty mounting narrow beads to inflate. The following word very well and almost no cost. purchase a 16”bicycle inner tube at Walmart $6 bucks. After tire mounted on rim. Tire lube stuf very liberally. Stuff The 16” bike tire in the top of the rim lip. Keep slippery inflate the bike tube jut till it fills the gap. Inflate the tire valve out the side. Inflate the tire which is now holding air as it is being filled. Thbike innertube will squeeze out of the wheel. Don’t be shy after bead comes up pull out the bike tube whil filling the tire fully. Works great. Use bike tube for your size rim. 16” etc Stuff into rim evenly keep it slippery you will figure it out good luck!!
lgndlt5 is offline   Reply With Quote
Old 07-29-2021, 03:13 PM   #16
lgndlt5
Adding due to typos do not over inflate bike tube too much just enough to seal the gap valve core out of tire keep it very slippery with tire mounting lube it will pop out mostly as beads seat grab it and pull the bike tube out as you add air.
Old 07-29-2021, 05:00 PM   #17
Steve in Denver
Steve in Denver's Avatar
Just, and I mean Just, put Double White Walls with the beauty rings on my '36. Still have not washed the blue stuff off of the whitewalls on the spare, hope to do that this weekend.
Diamond Back makes tires to order, took 5 weeks to get them and the cost was around $2500, plus another $100 to have them spin balanced. I had to borrow the wide five to normal 5 reducer from a friend so they could spin balance them.
Will post pictures when I get it all put together.
Steve in Denver is offline   Reply With Quote
Old 07-29-2021, 06:15 PM   #18
Ray Balukas
Ray Balukas's Avatar
Love the DB's.
Ray Balukas is offline   Reply With Quote
Old 07-29-2021, 06:40 PM   #19
mercman from oz
mercman from oz's Avatar
These Wide White Walls look great.
Old 07-29-2021, 06:51 PM   #20
Bored&Stroked
Bored&Stroked's Avatar
Curious on the pricing . . . when I went to their website the prices seemed about $350 at the high end, how did your total get up to $2500?
