Old 10-24-2021, 01:49 PM   #1
WRA
WRA's Avatar
Default Model B Flywheel Housing Alignment
Does the Model B flywheel housing need to be aligned like the Model A housing.
WRA is offline   Reply With Quote
Old 10-24-2021, 02:54 PM   #2
DavidG
DavidG's Avatar
Default Re: Model B Flywheel Housing Alignment
I've not found a need on the several that I've restored nor is there any reference to such a need in all the Ford '32 service information that I've encountered over the years, but I'm sure that it wouldn't hurt to do so. Perhaps the change to a full length oil pan and half of a cast bell housing eliminated the need.
Old 10-24-2021, 04:41 PM   #3
Pete
Pete's Avatar
It should be done on ALL engines. You may get away without doing it if you are lucky.
Old 10-24-2021, 06:52 PM   #4
DavidG
DavidG's Avatar
Right, even though the subject components have operated successfully together for going on 90 years. Perhaps if the subject parts have to be replaced for one reason or another, okay, but Ford's tolerances weren't that sloppy when these things were manufactured.
