Old 12-22-2020, 05:58 PM   #1
Clem Clement
Clem Clement's Avatar
Default 40 Merc under-dash switches
I'm gingerly exploring my 40Merc. Under the dash on the driver's side there are a rheostat knob for the dash lights and an no/off switch. The dash has mounting holes for the switch which seem factory. I see nothing on the wiring diagram. When I first bought the car in 1956, it had a driver's side spotlight which is now gone.
Gone is the day when I could work upside down... (I turned the switch on and beer flowed out of the horn button...that is factory , right?
Merry Christmas,
Clem
Clem Clement is offline   Reply With Quote
Old 12-22-2020, 10:19 PM   #2
Zeke3
Zeke3's Avatar
Default Re: 40 Merc under-dash switches
Was it a lager, ale or porter?
Zeke3 is offline   Reply With Quote
Old 12-23-2020, 08:47 AM   #3
1931 flamingo
1931 flamingo's Avatar
Love your humor ! !
MERRY CHRISTMAS and a HAPPY, HEALTHY NEW YEAR ! ! !
Paul
Old 12-23-2020, 10:52 PM   #4
Clem Clement
1931 Flamingo,
Thanks. I my retired capacity, I don't have the strength to lug and hug as I used to. Still my life's goal is to help make other folks happy. Thus the silliness in my writing and thinking.
Merry Christmas,
Clem
Old 12-24-2020, 01:29 PM   #5
Clem Clement
Parkbrauerei / Park & Bellheimer AG | Pirmasens, Germany ...
Immer schmect
Old 12-24-2020, 02:32 PM   #6
Zeke3
Zeke3's Avatar
Klingt erfrischend.
Old 12-24-2020, 02:38 PM   #7
mfirth
Ich verstehe nicht, i do understand ale tho & CGRISTmas.....
mfirth is offline   Reply With Quote
Old 12-24-2020, 03:21 PM   #8
Clem Clement
Parkbrau was my fav local beer while stationed in Germany
Old 12-24-2020, 03:29 PM   #9
Clem Clement
There is a wire from the ignition to the paddle switch.
Old 12-25-2020, 01:47 PM   #10
Clem Clement
The wire goes thru the paddle switch and to the firewall Resister's left end???
Old 12-26-2020, 11:06 AM   #11
JayChicago
JayChicago's Avatar
So this switch provides temporary by-pass of the resister to help with starting, added by a previous owner.
JayChicago is offline   Reply With Quote
Old 12-26-2020, 03:52 PM   #12
Clem Clement
Turn it on for starting and then shut it off? If I leave it on, I cook the coil?
Old 12-26-2020, 04:03 PM   #13
Ggmac
Isnt the on off switch for the dome - interior lights ?
Ggmac is offline   Reply With Quote
Old 12-26-2020, 05:26 PM   #14
rotorwrench
rotorwrench's Avatar
The integral instrument lamp dimmer and light switch came later than 1940. I think the 1942 Mercury did have a separate instrument lamp dimmer rheostat but I'm not sure about 1940. Heater set ups could have a rheostat switch for the fan motor but it depends on the heater type whether factory or aftermarket. Dome light switches were either close to the light or on the B-pillar in many old Fords clear up into the 50s.
It's harder to find information for Mercury cars but they did share stuff with the Fords to a certain degree. The dashes were definitely different in the early years but they still had light, throttle, choke, vent, & wiper knobs. Some had overdrive control knobs if equipped and the convertibles had top control knobs. All of them had the column mounted ignition switch till 1948 or so.
Old 12-26-2020, 06:08 PM   #15
Clem Clement
This is a 40Merc fordor convertible sedan. No dome light. Dinner rheostat is separate and full of mold. Car has hot air heater. It will come out soon for inspection.
Thanks
Old 12-26-2020, 06:13 PM   #16
JayChicago
JayChicago's Avatar
Yes. And yes.
Old 12-27-2020, 10:59 AM   #17
1931 flamingo
" switch provides temporary by-pass of the resister to help with starting"
There was a discussion w/diagram on the EFV8 club board about this.
Paul in CT
Old 12-27-2020, 11:15 AM   #18
rotorwrench
I don't think a bypass switch for the ignition resistor would have been a factory item. If it is then that would be the first time I've gotten that information. It was likely added by a former owner. This is where photos of unknown things are needed to aid in identification and for future reference to others.
Old 12-27-2020, 12:49 PM   #19
deuce_roadster
deuce_roadster's Avatar
The dash light switch is integral with the headlight switch on 40 Fords, so I suspect same on a Merc. When the headlights are on, the dash lights are on and adjustable via the rheostat you found.
How is this for not being OT Mike!
Old 12-27-2020, 02:55 PM   #20
Clem Clement
I need to sort out the on position and so mark it. I have in the recent past noted that the starter cranks slowly. The switch is mounted on a pierce of small aluminum sheet screwed in place to the bottom lip of the curved dash next to the holes for the dash light rheostat. It is clearly not factory.
I removed and checked the dash light rheostat. The nichrome coil spring used to take off a lower voltage is disconnected at one end.
