06-17-2018, 04:20 AM | #1 |
Model A motor and trans weight
Does anyone have an online ref. to the weight of a Model A motor and trans. from 1929 ? Thanks [email protected]
06-17-2018, 08:51 AM | #2 |
Re: Model A motor and trans weight
Weight (Lbs) Short Block 207 Long Block 358 Engine Ready to Run with Manifolds, Carburetor, Generator, Starter & Less Clutch Housing & Transmission 400 Running Engine with Flywheel, Clutch & Transmission 473 Camshaft Clutch Connecting Rod 1.375 Crankshaft (No Counterweights) 28 Flywheel 63 Piston, Rings & Pin 1.55
Bob Bidonde |
