Old 11-24-2011, 05:14 PM   #21
Marco Tahtaras
Marco Tahtaras's Avatar
Default Re: Model A Parts That Never Changed Throughout Production
Originally Posted by Kevin in NJ View Post
What about the brackets that the rumble hinges are bolted too?
The braces that were welded to the bottom of the rumble pan?
How about the rumble pan itself?
The initial hinges (probably used into late 1928 were steel forgings. These were later changed to malleable castings I believe. There were numerous changes to most if not all floor pans of the Ford bodied cars.
http://www.abarnyard.com/
Marco Tahtaras is offline   Reply With Quote
Old 11-24-2011, 06:19 PM   #22
Jim Parker Toronto
Jim Parker Toronto's Avatar
My vote, after some thought, would be the fan...... The question certainly is a good one to get you thinking!
Jim Parker Toronto is offline   Reply With Quote
Old 11-24-2011, 06:43 PM   #23
LukeDahlinger
The fan changed too! Late 31 went to a single thickness instead of the troublesome double thickness fans. Then again, I wouldn't run an original fan on a driver car with the availability of aluminum one piece fans.
Wanted- Feb. 1931 Parts Price List
www.vintagefordfacts.blogspot.com
LukeDahlinger is offline   Reply With Quote
Old 11-24-2011, 07:36 PM   #24
Tom Wesenberg
Tom Wesenberg's Avatar
Maybe the key ring stayed the same?
Old 11-24-2011, 08:00 PM   #25
BudP
BudP's Avatar
Brent,
What are the Benson archives?
How are they accessed?
Thanks a lot
BudP is offline   Reply With Quote
Old 11-24-2011, 09:22 PM   #26
mot
Registered User
mot's Avatar
not sure whats going to come out in the new JS but there are at least two screwdrivers,anyway the finish differed
at least three fans
,the horn conduit was fiber in the trucks
the 28-29s were plated,the 30-31s were stainless
there was a high compression head availible
tires were 21 in 28-29 and 19 in 30-31
some vehicles like the station wagon had 500/19s in 30-31
mot is offline   Reply With Quote
Old 11-24-2011, 09:53 PM   #27
BRENT in 10-uh-C
BRENT in 10-uh-C's Avatar
Well, it appears this little exercise is turning into a real puzzler ain't it??
Originally Posted by BudP View Post
Brent,
Thanks a lot
It is the Bensen Ford Research Library. Click HERE for more info...
BRENT in 10-uh-C
www.model-a-ford.com
...(...Finally Updated!! )
Old 11-24-2011, 10:13 PM   #28
Kevin in NJ
Air in the tires?
Kevin in NJ is offline   Reply With Quote
Old 11-24-2011, 10:17 PM   #29
Rowdy
Puzzler for sure, then to get bashed for being specific about parts on the swapmeet when you put the year and or months it was used. It has not happened recently, but has happened more than once. Rod
Do the RIGHT thing - Support the H.A.M.B. Alliance!!!!
Rowdy is offline   Reply With Quote
Old 11-24-2011, 10:18 PM   #30
dave in australia
I'm not saying they are, but what about the front brake push rod that moves the wedge, and the wedge itself. Are they different on the early 28 brake system?
dave in australia is offline   Reply With Quote
Old 11-24-2011, 10:23 PM   #31
J Franklin
J Franklin's Avatar
Points, rotor, cap, and Condenser?
Old 11-24-2011, 11:32 PM   #32
Midwest Tin
Midwest Tin's Avatar
The brake clevis pins. A-2461 Jim Sinclair
Midwest Tin is offline   Reply With Quote
Old 11-24-2011, 11:45 PM   #33
Jim Parker Toronto
Cotter pins.......
Old 11-25-2011, 09:19 AM   #34
gweilbaker
gweilbaker's Avatar
Grease zerks?
And the nut behind the wheel.
gweilbaker is offline   Reply With Quote
