Old 01-15-2021, 10:50 AM   #1
kawagumby
kawagumby's Avatar
Default Water pump questions
Hi folks,
I'm going through everything on my '31, and have a question about the water pump. The pump is new, has a stainless steel shaft and I just packed it about 30 miles ago. It doesn't leak, but the shaft turns with a lot of resistance (with no belt) relative to a modern water pump. I coated the packing with silicon grease and that helped, but it is still fairly tight even though I haven't over-torqued the packing nut. Should the shaft have such resistance with the packing system? Also, the pump has a lot of end play...which seems odd - is that normal? I'm wondering if a leakless pump might be better.
Tom
kawagumby is offline   Reply With Quote
Old 01-15-2021, 11:37 AM   #2
Gary WA
Gary WA's Avatar
Default Re: Water pump questions
I prefer leakless, but the originals rebuilt are great too!
www.whidbeymodelaclub.com
Old 01-15-2021, 12:50 PM   #3
Bmoody
End play could be due to wear in the head where the shaft rides. I replaced my packing with leakless seal. You cant see it behind the packing nut and it hasnt leaked a drop in 4 years. Be careful not to overtighten
Bmoody is offline   Reply With Quote
Old 01-15-2021, 01:27 PM   #4
Jacksonlll
Jacksonlll's Avatar
Send a message via ICQ to Jacksonlll
Run it a while and see if it loosens up a bit. You should be good with that new packing for many years.
Jacksonlll is offline   Reply With Quote
Old 01-15-2021, 01:45 PM   #5
alexiskai
alexiskai's Avatar
That's been my experience, it feels tight when it hasn't been turned for awhile. If you bolt the fan on and spin the fan blade by hand for a minute or so, it loosens up (again, my experience).
Old 01-15-2021, 03:23 PM   #6
Synchro909
Synchro909's Avatar
The original style water pump is a poor design, IMO. To say they last for years only says to me that the car is hardly used. The stainless steel shafts we have to use these days are soft. The packing wears them quite quickly and the front roller bearing chews them up. There have been several attempts to improve them but you can only do so much polishing on a turd. I make my own from scratch with ball bearings and a modern ceramic seal that will outlast any of the others. I need that when we are long distance touring. Our trip to and from one National meet took us 3 1/2 months and over 12,000 miles so reliability was paramount.
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
Old 01-15-2021, 03:37 PM   #7
Bill Cilker
Bill Cilker's Avatar
If your water pump is rebuilt like an original, the packing nut should only be tightened enough to stop the water from leaking,
Bill Cilker, Jr
Unrestored 190A Victoria
45B, 160B & 189A
Victoria Association President
Bill Cilker is offline   Reply With Quote
Old 01-15-2021, 03:42 PM   #8
kawagumby
kawagumby's Avatar
Thanks all,
Lots of good feedback. I'll put some more miles on it once I get the engine back together, and see if it loosens up some. If not, I'll go leakless.
Old 01-15-2021, 04:16 PM   #9
twilder
twilder's Avatar
This is what my water pump looks like. Any suggestions as to what kind it is? It looks nothing like others I have seen. Seems to work fine though. I have been told it's an industrial pump or one from a tractor
[ATTACH]452939[[ATTACH]
twilder is offline   Reply With Quote
Old 01-15-2021, 07:44 PM   #10
David R.
You could build up a little brass on the end of the shaft to take up for wear on the head to eliminate the end play or add a little set collar. My old pump had the set collar on it so I re-used it when I rebuilt it.
David R. is offline   Reply With Quote
