Old 10-15-2020, 05:15 AM   #1
tomkc1
tomkc1's Avatar
Default '34 Ford Hood Latch
The latch on my hood (the one closest to the firewall on the passenger side) is frozen in place and won't move down that 1/2 inch or so. It doesn't move at all. I can't figure out if somehow it broke or its so tight that I can't move it but I've put a lot of pressure on it so I suspect that it might have broken.
Anyone have any ideas as to how to release it?
As always, thanks.
Tom
tomkc1 is offline   Reply With Quote
Old 10-15-2020, 12:18 PM   #2
JimG
JimG's Avatar
Default Re: '34 Ford Hood Latch
There are two versions of this latch - early and late. This thread describes them. I have the early style. Hard to see what could be binding it if the spring broke on the early style. Which style do you have?
https://www.fordbarn.com/forum/showt...=34+hood+latch
JimG is offline   Reply With Quote
Old 10-15-2020, 06:27 PM   #3
tomkc1
tomkc1's Avatar
Jim, I have the later version, the spring is inside. Should the springs be lubricated, by the way? Do they break and thus make it impossible to move the latch?
Tom
Old 10-15-2020, 06:37 PM   #4
mercman from oz
mercman from oz's Avatar
Here is a photo of the two styles of Hood Latch. The one on the left with the exposed spring is the early issue. Hope that this helps.
Old 10-17-2020, 04:59 AM   #5
tomkc1
tomkc1's Avatar
No other suggestions, guys? We've determined that its the newer style. I'd like to be able to open that side of the hood since I have to get to the starter wire.
Tom
Old 10-17-2020, 05:18 AM   #6
koates
Sometimes these latches are a bit hard and you have to give them a bloody good shove downwards. Dont be gentle, lean on it like you dont like it. Regards. Kevin.
koates is offline   Reply With Quote
Old 10-17-2020, 07:23 AM   #7
JimG
JimG's Avatar
It's a spring loaded lever. I don't know what else to suggest other than brute force.
Old 10-17-2020, 10:07 AM   #8
tomkc1
tomkc1's Avatar
Thank you Jim. Brute force did it. Actually I pried it down with a screw driver.
It was tough. Thanks again. Tom
Old 10-17-2020, 04:24 PM   #9
JimG
JimG's Avatar
A longer lever! Archimedes would be proud! Did you figure out why it was sticking?
Old 10-18-2020, 04:30 AM   #10
tomkc1
tomkc1's Avatar
Not yet, but I will. Thank's again.
