06-04-2020, 06:26 AM | #1 |
Trico Vacuum Wiper
I have a 29 tudor that has a Trico vacuum wiper motor on it. From what all I have searched and read it is not original. It is a mirror image of a Trico TR-C2A. Mounts only off of the Shaft with no brackets. Binds up so the windshield won't open. Does it matter what position they mount? Any idea what it really fits?
06-04-2020, 06:31 AM | #2 |
Re: Trico Vacuum Wiper
A picture would help. It may be for slant windshield. The shaft would be about 2 1/2 long.
Brian SATX |
06-04-2020, 07:04 AM | #3 |
Picture attached. Yes the shaft is 2 7/8" long.
06-04-2020, 07:17 AM | #4 |
This is what I found for the slant windshield
06-04-2020, 07:26 AM | #5 |
Looks like you found it.
Just in case you haven't seen it, this is a wealth of wiper info. https://www.mafca.com/downloads/Semi...A%20Wipers.pdf |
06-04-2020, 07:42 AM | #6 | |
I have read all of that. If you look close, the one I have has the switch and vacuum connection opposite. |
06-04-2020, 07:43 AM | #7 |
Will it work mounted upside down?
06-04-2020, 08:03 AM | #8 |
I think 29’s all had electric wipers didn’t they? Unless it is a really late model.
Mike
1930 TownSedan (Briggs) 1957 Country Sedan |
06-04-2020, 08:20 AM | #9 |
06-04-2020, 08:22 AM | #10 |
06-04-2020, 09:51 AM | #11 |
06-04-2020, 10:08 AM | #12 |
06-05-2020, 09:35 AM | #13 |
What you have is a vacuum wiper for a Chevrolet.
If you have a later '29 tudor the vacuum wiper motor is installed on the outside See Bob's picture below Last edited by Joop; 06-05-2020 at 12:00 PM. |
06-05-2020, 10:53 AM | #14 |
I think this is the wiper you need.
06-06-2020, 05:58 AM | #15 |
I don't know if I have a late or early 29. The engine number is April 1930.
06-06-2020, 06:21 AM | #16 |
My 29 Special Coupe has a vacuum wiper.
06-06-2020, 09:51 AM | #17 | |
This picture that Marco posted may help you determine what wiper your car originally had. |
06-06-2020, 05:12 PM | #18 | |
Yes, I have seen that. Mine measures 12 3/4". I did figure out a way to make the vacuum motor work and still open the windshield. All I had to do was use a longer spacer on the shaft so the motor would clear the edge of the header when the windshield swings out. Then made a cover plate to cover up the unused holes in the windshield frame. Motor is mounted on the inside. Maybe it isn't correct but it looks good and works. Last edited by DBSHELTON; 06-06-2020 at 05:18 PM. |
06-06-2020, 05:16 PM | #19 |
06-06-2020, 08:56 PM | #20 |
Looks like 4 3/4"
