Old 07-05-2011, 12:35 PM   #1
HOTROD_WILLIE
HOTROD_WILLIE's Avatar
Default Electric Fuel Pump Problems is it Bad Gas
I am running electric 12V fuel pump on my flathead motor. I have replaced 3 of them in past in a month time. The pumps I have been buy are from your local part stores. I don't even drive my car that much. I was think the Alcohol that is now in the gas is kill my pumps. Does anybody know a good brand of pumps that would be great for Flathead motor? Thanks for you time.
HOTROD_WILLIE is offline   Reply With Quote
Old 07-05-2011, 12:51 PM   #2
4dFord/SC
4dFord/SC's Avatar
Default Re: Electric Fuel Pump Problems is it Bad Gas
I've been using an Airtex 6v pump for over seven years with no problems. I believe the 12v version is p/n E8012S.
4dFord/SC is offline   Reply With Quote
Old 07-05-2011, 01:08 PM   #3
37ford4dr
37ford4dr's Avatar
do you have filter in between the pump and the gas tank?
37ford4dr is offline   Reply With Quote
Old 07-05-2011, 03:46 PM   #4
darrenct83
In my opinion Carter makes the best fuel pumps. Make sure you are using a pump designed for carburetors. Also make sure you use a filter. Mount your pump as low and close to the tank as possible. Additionally make sure that you are using at least 14 guage wire or larger with good connections. A fuel pump is a much higher amperage draw than these old rigs are used to. Wire accordingly. I power mine using a relay so the actual power comes directly off of the battery, and the ignition switch switches it on.
darrenct83 is offline   Reply With Quote
Old 07-05-2011, 04:56 PM   #5
Frank The Plumber
You pay too little you get little back.
Frank The Plumber is offline   Reply With Quote
Old 07-05-2011, 07:53 PM   #6
George/Maine
George/Maine's Avatar
I bought one from NAPA has a filter on it.Says mount close to tank better to push gas.I tryed to lift gas out of tank with hose a didn,t work.If you can drain gas, start with new and could have line pluged.
George/Maine is offline   Reply With Quote
Old 07-05-2011, 11:24 PM   #7
Ralph Moore
Ralph Moore's Avatar
Need Another Part Again!
Ralph Moore is offline   Reply With Quote
Old 07-06-2011, 01:39 AM   #8
OldDad
OldDad's Avatar
This is probably off topic, but I think you may find it interesting that I am currently running a Bendix 6v pump from sometime prior to 1965 on my '40 coupe. I would guess this was manufactured around 1960. Car was parked in 1966, sat until 1985, drove it for six months, then got it running again in March of 2010. Sits more often than drives, and so far no problems, soaked in new gas. I can't believe it keeps ticking, but with AAA watching my back, I motor on.
OldDad is offline   Reply With Quote
Old 07-06-2011, 07:58 AM   #9
Tom Morookian
Tom Morookian's Avatar
Silly question, are you running your 12V pump on 6 V? That'll kill it.
Tom Morookian is offline   Reply With Quote
Old 07-06-2011, 01:48 PM   #10
Marv
Marv's Avatar
If your pumps are not made to use with alchohol, that is probably the problem with your pumps. Gasoline with alchohol in it will ruin them. Marv
Marv is offline   Reply With Quote
Old 07-06-2011, 05:04 PM   #11
dude
dude's Avatar
Are we talking 6V or 12V? alcohol or ethanol? Pump should definitely last longer than a couple weeks. I've used Holley low pressure pump for over 11 years. Don't think your problem is the pump,maybe wiring or flow restriction.
[QUO[/QUOTE]no matter where you are,or where you're at, there you are...
dude is offline   Reply With Quote
Old 07-07-2011, 05:22 PM   #12
Marv
Marv's Avatar
I was thinking pumps made for racing fuel alchohol, should hold up with ethanhol. Regular pumps will not. Marv
Old 07-07-2011, 05:31 PM   #13
Pete
Pete's Avatar
Correct.
I have been running a Holley race pump on the street for 10 years. No problems.
It is designed to run alcohol, nitromethane or any kind of gas.
Old 07-08-2011, 07:13 AM   #14
John Kennedy
John Kennedy's Avatar
Check wiring, verify your grounds.
Check for blockage in tank and lines.
Make sure there's decent filters before and after pump. "Push thru paper, suck thru screen".
Mount pump near and lower than tank if possible.
Building a 29 Sedan on 32 chassis........ very slowly....
John Kennedy is offline   Reply With Quote
Old 07-08-2011, 09:48 AM   #15
John T
I have been running 2 vehicles with Carter rotary pumps, one for 4 years and no problems with either one.
John T is offline   Reply With Quote
Old 07-10-2011, 08:18 AM   #16
Ford coupe
I run an electric 6 volt on my 55 and 36 flattie for start only 36 works great and 55 helps very very little.Both comes from Macs and are mounted similar...low and close to tank.Does anyone know the manufacturer of these pumps...
Ford coupe is offline   Reply With Quote
