Old 10-22-2020, 01:06 PM   #1
Jacques1960
Jacques1960's Avatar
Default Bullet connector crimping tool
The bullet connectors on my 38 have four (opposing) crimps per below photo; the Lucas style crimping tool I have simply mashes the connector.
What is the correct tool to achieve the original style crimp ?
Thank you
No job’s done ‘til it’s all done
Jacques1960 is offline   Reply With Quote
Old 10-22-2020, 01:45 PM   #2
Kurt in NJ
Kurt in NJ's Avatar
Default Re: Bullet connector crimping tool
I don't have a picture, have the tool, pliers with hole, as squeeze 4 pins crimp, has end cap to position connecter
Old 10-22-2020, 01:50 PM   #3
G.M.
There is a pliers type tool that you put the bullet connector
in, squeeze the handles and a bunch of little pins come in
and squeeze the recessed part of the bullet. G.M.
www.fordcollector.com
Old 10-22-2020, 01:55 PM   #4
1931 flamingo
1931 flamingo's Avatar
Or you could solder them to the wire(s).
Paul in CT
Old 10-22-2020, 01:56 PM   #5
richard crow
i solder them much. better than a crimp
richard crow is offline   Reply With Quote
Old 10-22-2020, 03:07 PM   #6
51 MERC-CT
51 MERC-CT's Avatar
When I ordered my new wiring harness from http://www.riwire.com/ I also ordered some extra bullet connectors for circuits that I was adding.
Some suppliers only supply machined bullets that will not crimp but fracture and should only be soldered.
Did a little massaging on one of my tools and it worked for me.
The trick is not to over crimp.
Old 10-22-2020, 04:11 PM   #7
Jacques1960
Interesting - I have an old Radio Shack crimper now begging for a date with the Dremel !
Old 10-22-2020, 05:22 PM   #8
Jacques1960
Also, as an experiment, I’m going to borrow a Triumph / Norton hexagonal crimper and see how (if) this works on Dennis Carpenter brass bullet connectors
Old 10-22-2020, 06:21 PM   #9
Veeder
I soldered all mine - that's my vote very easy
Veeder is offline   Reply With Quote
Old 10-24-2020, 08:07 AM   #10
Jacques1960
CW Moss has the (hopefully softer) white metal bullet connectors in their Model A catalogue; the hard brass ones from Carpenter and RI Wiring both seem to be solder only propositions due to hardness. Will update once new tool arrives and will try on both “hard” and “soft” connectors
Old 10-24-2020, 02:40 PM   #11
51 MERC-CT
51 MERC-CT's Avatar
The bullets that I got from RI wire are (soft brass) crimp and solder, the same as they list now.
Old 10-26-2020, 10:23 AM   #12
Jacques1960
Eureka ! The Bonneville Shop, which specializes in Brit bikes like Triumph and Norton, just delivered a ratcheting hexagonal bullet crimper capable of forming perfect crimps on both hardened and white metal bullet connectors. Between this and a dab of solder, the connections on my 38 should be good for another 80+ years
Old 10-26-2020, 10:28 AM   #13
Jacques1960
Photo included: Lucas style on top (worthless POS), Bonneville Shop below
Old 10-26-2020, 10:36 AM   #14
1948F-1Pickup
1948F-1Pickup's Avatar
Nice. That's a pricey little tool at $95 though.
1948F-1Pickup is offline   Reply With Quote
Old 10-26-2020, 11:00 AM   #15
Jacques1960
It is, but you know how it can be with purpose-built tools
Old 10-26-2020, 01:19 PM   #16
Kurt in NJ
Kurt in NJ's Avatar
Here's the crimper I have--- 4 pins crimp at same time
Old 10-26-2020, 01:36 PM   #17
JSeery
JSeery's Avatar
Any idea on the brand?
Old 10-26-2020, 02:55 PM   #18
1948F-1Pickup
That's a Buchanan....
https://www.ebay.com/itm/153413606656
Old 10-26-2020, 03:13 PM   #19
Jacques1960
Spot on, and a great price
Old 10-26-2020, 03:52 PM   #20
rotorwrench
rotorwrench's Avatar
I have a bunch of Daniels crimpers for aircraft use that are 4-way. The large size is less common but they are out there.
