08-12-2020, 11:17 AM | #1 |
Gas Tank Renu
Has anybody have their gas tank inside coated and sealed by GAS Tank Renu and had a failure? We had a carb problem and found tiny black specs in the carb. Suspected the flex line as the problem. Removed the flex line a found lots of black specs at the fuel pump end. Cut the flex line in half and found a plastic liner in the line preventing gas to come in contact with the rubber. Thanks Skip for that. Siphoned some gas from the tank and found black specs and residue in the gas. The source of the specs is from the inside of the tank or bad gas. Gas Tank Renu has not been to responsive to this problem as their work has a lifetime warrenty. Any body have any comments on this problem.
