Old 07-31-2020, 03:45 PM   #1
flathead 53
Default S-10 transmission on a flathead
Anyone do this swap ? looking to do this on A 53 f-100, what problems did you run into, clutch, adapter plate etc, thanks.
flathead 53 is offline   Reply With Quote
Old 07-31-2020, 03:50 PM   #2
TagMan
Default Re: S-10 transmission on a flathead
Not really a "on topic" question for this board, but you might want to do a search on the subject.
As an alternative, check out HAMB. There's a ton of information over there about this very subject.
TagMan is offline   Reply With Quote
Old 07-31-2020, 03:54 PM   #3
RalphM
RalphM's Avatar
I believe if you do a search there are several threads in this subject.
Also a conversion kit shows up occasionally in the for sale ads here.
RalphM is offline   Reply With Quote
Old 07-31-2020, 04:25 PM   #4
leon bee
Just google "ford flathead T5."
Edit: Google "Ford flathead T5 conversion". About a million hits.
leon bee is offline   Reply With Quote
Old 07-31-2020, 04:31 PM   #5
Bob C
I think that is one of the more difficult swaps because the bell housing is one year
only and the motor mounts bolt to the bell housing. There was a thread about this in
the past.
Old 07-31-2020, 07:09 PM   #6
32phil
I have a 32 Tudor that has an 8BA and a S10
I didn't do the swap........... I bought the car that way from a late friends widow.
It's a pretty simple swap as far as the engine to trans piece.
He used a V8 "hogshead" and an aluminum home built plate (aftermarket plates are available) drilled for the S10 pattern.
The 32 pedals are in place and remain untouched.
I think he used the Ford pressure plate and the correct clutch disc for the S10 spline.
The S10 requires modification to the 32 center crossmember and is open drive.
It's an easy job for your F100 as it is already open drive.
Early Ford Lock & Key Service
http://www.fordbarn.com/forum/showthread.php?t=46583
32phil is offline   Reply With Quote
Old 07-31-2020, 07:55 PM   #7
skidmarks
skidmarks's Avatar
The 53 bellhousing can be done like the mumert y block bell, but the T170 would be a much better choice.
The other issue is your clutch linkage..its more of a challenge then the 1952 and older pickup
They made an adapter were you could bolt a muncie to the y block pattern which is the same as a 53 pickup transmission and vise versa but those adapters are pricey .
skidmarks is offline   Reply With Quote
