Old 04-04-2020, 08:36 PM   #1
1939 dave
Default gas gauge 1939 tonner
what should be the voltage at the connection on sending unit with the wire disconnected?
1939 dave is offline   Reply With Quote
Old 04-04-2020, 09:03 PM   #2
JSeery
JSeery's Avatar
Default Re: gas gauge 1939 tonner
On the connection itself? zero, it is a path to ground. The current flows from the gauge in the instrument panel to the sender to ground.
Old 04-04-2020, 09:26 PM   #3
1939 dave
I installed new sending unit, gauge not showing anything truck has been sitting for 35 yr. don:t condition of gauge itself any ideas
Old 04-04-2020, 09:39 PM   #4
tubman
tubman's Avatar
Same old problem. Ford gauges use the "King-Seeley" system which works differently from most other systems. Most (probably all) replacement sending units are the resistance type and won't work well in Ford systems. Touching the wire to ground should make the gauge move. If it doesn't, either the gauge or the wire to it is bad. Try a jumper from the terminal on the gauge to ground. No action, the gauge is bad; if the gauge moves, the wire to the gauge is bad. Only touch the wire to ground for a short time or you will have other problems.
Old 04-04-2020, 09:53 PM   #5
JSeery
JSeery's Avatar
I assumed we were talking original here, see that is not the case! Still zero at the sender connection, but it will be a resistance unit.
Old 04-04-2020, 09:57 PM   #6
tubman
tubman's Avatar
Originally Posted by JSeery View Post
I made the assumed we were talking original here, see that is not the case! Still zero at the sender connection, but it will be a resistance unit.
He said the truck has been sitting 35 years. I don't see what is wrong with your original assumption.
Old 04-05-2020, 09:24 AM   #7
19Fordy
19Fordy's Avatar
Will this little pictorial help in checking your set up?
Old 04-05-2020, 09:28 AM   #8
alanwoodieman
run a ground wire from one of the screws holding the gauge to the tank to a good clean location--grounded mine to the cab back wall with ign on, if you momentarily touch the gauge wire to this ground does the gauge on the dash work?
Old 04-05-2020, 10:07 AM   #9
KGS
KGS's Avatar
Should be positive ground for the 6 volt system on the Ford. Yes?
KGS is offline   Reply With Quote
