03-16-2024, 02:52 PM | #1 |
One Fast Flathead
Click on the video and enjoy
https://www.jalopyjournal.com/?p=57839 |
03-16-2024, 03:16 PM | #2 |
Re: One Fast Flathead
That was beautiful. The thumbs up at the end spoke a thousand words.
03-16-2024, 04:30 PM | #3 |
LOVED IT !!!!!!!! Goose bumps galore! Wonder about RPMs?
03-16-2024, 06:25 PM | #4 |
Look on YouTube,under blown flathead dragster at benaraby.
Lawrie |
03-17-2024, 08:18 AM | #5 |
I raced door slammers at SIR and Bremerton Washington for many years and this made me feel like I was right back in the day. Thanks ,Tim
03-17-2024, 09:58 AM | #6 |
03-17-2024, 01:43 PM | #7 |
03-17-2024, 05:03 PM | #8 |
Rick Schnell's Blown flathead burning nitro methane fuel on an engine dyno is capable of making 900 Horsepower. RPM is 7000 at the 1320 1/4 mile mark. Block is filled with aluminum then the intake and exhaust ports are modified. The heads start as a solid block of aluminum then Rick machines the combustion chambers to work in the extreme environment burning nitro. Many years of development went into the Sliders engine to produce the power needed to run near 180 MPH in the quarter mile.
Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
03-17-2024, 06:19 PM | #9 |
Ronnie How many runs can that engine make?
Works good Lasts long time |
03-17-2024, 08:41 PM | #10 |
The only time I saw the car it made two runs that day. There's never really been any other competition to run against Ricks car so going rounds at an event wasn't done to my knowledge. Exhibition runs were more what the do when the car runs. On occasion when Rick was pushing the envelope if he experienced a lean out that always would cause a damaged piston and cylinder which at times meant another block would be needed. That would not be an easy job replacing the block considering the amount of work it takes to modify the blocks. Ronnieroadster
03-17-2024, 09:45 PM | #11 |
And after all that he is still leaving a LOT of power on the table.
If he were to pursue it, who would he race? He is in no man's land. Too fast for vintage and too slow for NHRA. |
03-18-2024, 03:44 PM | #12 |
What did Flathead Jack’s twin engine Flathead dragster run? I’ve never seen any times for it. It was a beautifully turned out piece. Does it still exist I wonder?
https://youtu.be/y9q6AS-11fs?si=cgYMK6YNYtk7Tteg |
03-18-2024, 03:56 PM | #13 |
Curious about your opening sentence. What more do you think could be done to make it go faster, Pete?
03-18-2024, 04:05 PM | #14 |
03-18-2024, 05:02 PM | #15 |
03-18-2024, 06:06 PM | #16 |
03-18-2024, 06:13 PM | #17 |
03-18-2024, 06:54 PM | #18 |
With those ideas the poor block wont take it for very long
03-18-2024, 06:57 PM | #19 |
03-18-2024, 07:00 PM | #20 |
Oh, I forgot to mention the next "up" blower would be a centrifugal.
More out for less in. |
