Old 07-14-2011, 06:22 PM   #1
V12Bill
V12Bill's Avatar
Default Front Oil Seal
I have to remove the pan on my 1939 221 engine to clean it out and repaint it. I was thinking of replacing the front oil seal with a newer one piece modern one. #1, What one piece seal would be the proper replacement and #2, Is it fruitless to replace the rope seal with something that may be no better? TIA
V12Bill is offline   Reply With Quote
Old 07-14-2011, 07:12 PM   #2
37 Coupe
37 Coupe's Avatar
Default Re: Front Oil Seal
The one I like is the rubber encased one that Speedway sells,probably others sell it. Walt Dupont gave me a heads up on this one while I was putting my 59AB together,little red silicone sealer on it and it fits snug and centers up real well. No leaks since.
"Never complain,never explain"... Henry Ford II
37 Coupe is offline   Reply With Quote
Old 07-14-2011, 09:17 PM   #3
40fordpu
40fordpu's Avatar
Yeah I heard that a one piece works nice. The silicone sealer is a must from what I understand. I wish I would have done it to my baby.
40fordpu is offline   Reply With Quote
Old 07-15-2011, 12:40 AM   #4
ford38v8
ford38v8's Avatar
So... any special instructions regarding the timing gear cover? Does the pan and cover have to go on & off together or what?
Alan
Old 07-15-2011, 07:34 AM   #5
Walt Dupont--Me.
Walt Dupont--Me.'s Avatar
Yes, you must install the seal in the front cover then install on the engine. Walt
Walt Dupont--Me. is offline   Reply With Quote
