07-13-2011, 09:32 PM | #1 |
59AB In A `51 Pickup
Just curious, will a 59AB bolt up to a`51 transmission?
Shadetree
Son, you will never blow an engine up in high gear. |
07-13-2011, 10:10 PM | #2 |
Re: 59AB In A `51 Pickup
Yes it will fit the 1/2 ton truck trans
07-14-2011, 09:08 AM | #3 |
1951 was a transition year, and the trans may not fit without an adapter. However the 49-50 transmissions will. A better choice would be the 49-50 Mercury trans with OD, you might have some clutch linkage putzing to do.
07-14-2011, 11:29 AM | #4 |
