Old 12-09-2022, 03:41 PM   #1
[email protected]
Default downdraft carb
I want to try a down draft carb . I have a two bolt down manifold . I guess I need adapter plate from 3 bolt (strongberg) to two bolt ,manifold . Is there another carb set up that would work with my manifold? steve any help would be great.
steveankc@gmail.com is offline   Reply With Quote
Old 12-09-2022, 10:33 PM   #2
jeepguy1948
Default Re: downdraft carb
I’m not trying to answer your question because I’m sorting it all out for myself as well. I am curious though, do you know what carburetor your manifold was made for?
jeepguy1948 is offline   Reply With Quote
Old 12-10-2022, 07:49 AM   #3
1929
Downdraft Stromberg 97
1929 is offline   Reply With Quote
Old 12-10-2022, 08:11 AM   #4
updraught
updraught's Avatar
There is a guy here called Petes Speed Shop, makes a dual downdraught manifold for twin two bolt Holden Stromberg carbs which were common in this neck of the woods. There are probably other 60's 6 cyl Strombergs similar.
Original 97's are rare here.
updraught is offline   Reply With Quote
Old 12-10-2022, 09:35 AM   #5
[email protected]
There was a cast iron strongberg carb on this manifold for 31 nash ,christyler. steve thanks,
Old 12-10-2022, 10:10 AM   #6
Richard in Anaheim CA
Richard in Anaheim CA's Avatar
Chevy 6's used 2 bolt carburetors for decades and are plentiful.
As a matter of interest, they used to use 5 of them on the Hot Rod GMC's
Richard in Anaheim CA is offline   Reply With Quote
Old 12-10-2022, 12:24 PM   #7
Flathead
Flathead's Avatar
I have an old aluminum downdraft A intake (not for sale) that came with a downdraft one barrel from a straight six Ford flathead. Haven't tried it yet but looks like a decent improvement from stock. Maybe look for one of those carbs.
Flathead is offline   Reply With Quote
