Old 05-07-2016, 11:26 AM   #1
freak
freak's Avatar
Default hub cap rattle
Any ideas on how to stop hubcaps from rattling? At least one of mine rattles and it is annoying. It's secure and not going to fall off but still rattles in the wheel.
freak is offline   Reply With Quote
Old 05-07-2016, 11:34 AM   #2
Fred S
Fred S's Avatar
Default Re: hub cap rattle
Silicone.
Fred S is offline   Reply With Quote
Old 05-07-2016, 11:39 AM   #3
freak
freak's Avatar
How are the hub caps held on? I've never had a wheel off.
Old 05-07-2016, 11:50 AM   #4
Mitch//pa
Tabs are bent over inside the rim.. If you tighten up the tabs better you should be ok..not all of them need to be bent... My experience has been is they won't rattle after securing them on good
Old 05-07-2016, 12:04 PM   #5
Phil Brown
Phil Brown's Avatar
Two or three small spots of silicone from the back side will fix the rattles and still let you remove them later on if you need to. But if the tabs are bent over tight they should not rattle
Phil Brown is offline   Reply With Quote
Old 05-07-2016, 12:16 PM   #6
brianpharmd
brianpharmd's Avatar
Take the wheel off and check the tabs. Some be missing/broken. I like to bend 4 or 5 over to secure the hubcap. Usually the ones near the lug holes on the rim. I start them with a small pair of pliers then lay the wheel upside down on a bunch of towels. Then use a screwdriver and hammer to secure the tabs to the rim. Then I check to see if the hubcap moves before I put the wheel back on.
Brian
brianpharmd is offline   Reply With Quote
Old 05-07-2016, 12:22 PM   #7
Art Newland
Art Newland's Avatar
Are your hubcap gaskets in good shape?
As temporary fix I put a few rubberbands around the caps. 8^)
http://www.mikes-afordable.com/product/A1130GS.html
Art Newland is offline   Reply With Quote
Old 05-07-2016, 01:00 PM   #8
Y-Blockhead
Y-Blockhead's Avatar
Hub Cap gaskets??
If you have a '30-31, Mike's sells a "Hub Cap Tool" http://www.mikes-afordable.com/product/T1130.html It reforms the tabs so the hub cab snaps on. No rubber bands needed. A little expensive but I have repaired enough hub caps (@ $10-$31 per) to pay for it.
Old 05-07-2016, 02:29 PM   #9
Bill Cilker
Bill Cilker's Avatar
For my 30-31 hubcaps I use a 3" or so thin O ring between the tabs and the inside of the wheel. The round hair thing that girls use on their hair to hold it also works well and you can get them easily.
Bill Cilker, Jr
Unrestored 190A Victoria
45B, 160B & 189A
Victoria Association President
Bill Cilker is offline   Reply With Quote
Old 05-07-2016, 02:57 PM   #10
1Tudoor
1Tudoor's Avatar
Yes, the hubcap rattle from the mangled tabs (former owner) required some kind of patience & skill I couldn't seem to muster so I clinched them the best I could & used the rubber o'rings from our 013 Camry used oil filters to act as seals/spacers ---they look & work great & I think are similar to what Mike's sells for cheap. I was going to order a set but found w/ my scrounge technology the Toyo filter ones did the trick. (I always save O rings)
BTW , stretching & popping in O rings seal the gap keeping out moisture & center the cap .
1Tudoor is offline   Reply With Quote
Old 05-07-2016, 07:11 PM   #11
Art Newland
So are the gaskets some aftermarket thing?
Old 05-07-2016, 10:02 PM   #12
Bruce Adams
Bruce Adams's Avatar
O-Rings ? Gaskets ?
WHAT could be better than a couple of dabs of Silicone ?
Simple, cheap, non-Invasive, Removable.
Bruce Adams is offline   Reply With Quote
Old 05-07-2016, 10:18 PM   #13
taffrail
taffrail's Avatar
The tab forming tool is great. I bend all ten tabs, feels tighter. It takes a little time to form them correctly. If you use O-rings you will have space the tool the thickness of the O-ring. They look like an electrical box knock-out plug when you get done. Haven't had a rattler or lost one in 8 years.
taffrail is offline   Reply With Quote
Old 05-07-2016, 11:00 PM   #14
C26Pinelake
First of all I have never heard of hubcap gaskets. I bend over half the tabs and place a gob of clear silicone on each one. No more rattles! Wayne
C26Pinelake is offline   Reply With Quote
Old 05-08-2016, 06:34 AM   #15
Capt Quahog
Capt Quahog's Avatar
Location: Barren windswept mountain somewhere in bleak Northeastern Pennsylvania
Interesting to find this topic at this time . . .
Yesterday afternoon, I pulled off the "symbolic" spare wheel from the back of the 31' Tudor so as to repaint the thing. Dislike color wheels on bread n' butter Model A Ford cars and this one came with RED. What sort of nut job paints the wheels on a Model A ford the color "RED"? Anyway, the spare wheel was removed and hub cap then taken off. After pressure washing, the wheel was blast painted a pleasing gloss BLACK. Later on when dried, the well polished hub cab was re-installed and numerous tabs carefully bent back into place nice n' snug. Mounted the wheel onto the spare holder and tightened the bolts as not to scratch up the new paint job. When done it was however noticed that the stupid hub cap was slightly loose so as to rattle. No way am I taking off that dumb wheel again any time soon. Forget about it!
So . . . the remedy was . . . . (Mister Bert Parks . . . the envelope please!) The winner is . . . . "LIQUID SUPER GLUE". And all the kiddies in the Peanut Gallery start screaming with delight. That's right River Rouge fans . . . . this incredibly clever home fix-it person used LIQUID SUPER GLUE" on a Model A Ford. Hell . . . it works like gangbusters on my 32-year old Mercedes Benz diesel sedan which is 67% plastic. It just took two (2) itsy bitsy teeny tiny drops of "LIQUID SUPER GLUE" to kibosh the hub cap rattle. The next idiot who has to remove that hub cap will likely need to use dynamite but I don't care.
Capt Quahog is offline   Reply With Quote
Old 05-08-2016, 09:06 AM   #16
Y-Blockhead
I like this guys way way better... Custom Hub Caps
Old 05-08-2016, 09:10 AM   #17
mshmodela
mshmodela's Avatar
Anyone try this method for hub caps...
https://www.youtube.com/watch?v=8l9141HNvCA
-Mike
Late 31' Ford Model A Tudor, Miss Daisy
I don't work on cars --I'm learning about my Model A.
Cleveland, Ohio
mshmodela is offline   Reply With Quote
Old 05-08-2016, 09:31 AM   #18
eagle
eagle's Avatar
I have original caps in quite nice shape. When I had the wheels off I took a 1/2 inch by 8-10 inch wooden dowel and holding the cap against my leg, put the dowel on each tab, through the rim center and gave it a tap. No rattle, the tabs are bent out quite a bit so I suppose it will be a bit difficult to get them off but they are nice and tight anyway.
"There are some that can destroy an anvil with a teaspoon and shouldn't be allowed to touch anything resembling a tool."
eagle is offline   Reply With Quote
Old 05-08-2016, 10:02 AM   #19
JOHN CT
JOHN CT's Avatar
I guess my A is not running like all of your A's I don't think I can hear a hub cap rattling around when I drive around! With all of the other rattles
JOHN CT is offline   Reply With Quote
Old 05-08-2016, 10:14 AM   #20
Russ/40
Russ/40's Avatar
Here is a fix. Take string, and from the inner center of the cap run the string out between two of the tabs. Run the string around the outside of the tabs and back into the center of the same gap you started from, and cut. Now you have just enough of a ring of string to serve as a gasket. It tightens and silences the cap.
Russ/40 is offline   Reply With Quote
Old 05-08-2016, 12:08 PM   #21
Y-Blockhead
Why not just bend the tabs correctly? I don't believe Model A's came from the factory with rubber bands, o rings, string, glue and/or silicone...
Old 05-08-2016, 12:44 PM   #22
Gary Karr
Gary Karr's Avatar
For the original 28/29 hubcaps, the tabs were not bent over. The caps were designed to simply pop into place and the tabs would hold the caps tight. If you look at pictures of the assembly lines of the 28/29's you will see some shots with the wheels installed without the caps. They were put on after the wheels were installed on the drums. I installed a NOS set of E-28 caps on my wheels and they did indeed pop into place and are super snug and will in no way rattle.
Gary Karr is offline   Reply With Quote
Old 05-08-2016, 12:50 PM   #23
Mitch//pa
Well said and correct
Old 05-09-2016, 10:39 AM   #24
Russ/40
Russ/40's Avatar
In my case, bending the tabs just made it harder to put them on, and they still rattled. Old repoes that came with the basket case.
Old 05-09-2016, 01:09 PM   #25
Fred K-OR
Fred K-OR's Avatar
I have found that the caps I have on my coupe, which are aftermarket, are impossible to bend the tabs to get them to not rattle. So I used the vendors rubber O rings and they work fine. On my huckster which has better caps, I can bend the caps to get them to not rattle. The huckster caps I think are after market also but are a better quality than the coupe's. So this is my experience for it is worth.
Fred Kroon
1929 Std Coupe
1929 Huckster
Fred K-OR is offline   Reply With Quote
Old 05-09-2016, 01:19 PM   #26
CarlG
CarlG's Avatar
Here's a picture of the tool referenced in post #8 above:
Alaskan A's
Model A Ford Club of America
Model A Restorers Club
Mullins Owner's Club
Old 05-09-2016, 01:24 PM   #27
JOHN CT
JOHN CT's Avatar
Do I have the only Model A that vibrates and rattles ??
Old 05-09-2016, 05:22 PM   #28
oldwoodsman
oldwoodsman's Avatar
John.... Maybe we got Monday built cars, or as the woman says I need a hearing aid.
oldwoodsman is offline   Reply With Quote
Old 05-09-2016, 07:37 PM   #29
Jwilli
Jwilli's Avatar
If you can hear the hub cap rattle, you have a very quiet car. ENJOY.
Jwilli is offline   Reply With Quote
