04-27-2021, 10:42 PM | #1 |
Pertronix Nightmare
Read a lot of pros and cons about Pertronix, had to see for myself. 1st one come in look like someone tried to install , wires cut! sent it back!! 2nd one installed NO SPARK! contacted customer service, this guy I talked to is in the wrong business! pretty much said I didn’t know what I was doing, that I installed it wrong, finally got him to email me how to bench test the unit. needless to say the unit tested bad. they say the third time’s the charm, not in this case! When it came in I benched tested it and it test good, finally!! Installed and it fired up, ran for about 5 minutes then died??? sent it back and back and staying with “POINTS”
04-27-2021, 11:02 PM | #2 |
Re: Pertronix Nightmare
Have had perfect luck with two sets...............
04-28-2021, 03:14 AM | #3 |
Pertronix units are very reliable on 12 volt cars. What car are you running it on and what voltage? Ignition coil must be a match for the Pertronix unit. If the coil pulls to much primary current then the Pertronix unit could be damaged. I think you have other issues apart from the Pertronix unit. Regards, Kevin.
04-28-2021, 05:52 AM | #4 |
I have never been left along the road with a set of points!!!
04-28-2021, 06:53 AM | #5 |
Never had an issue with Pertronix
04-28-2021, 07:46 AM | #6 |
They were all 12 volt, used correct Pertronix coil, & were the "Igniter 2" model. - F F
1952 Ford F1 1965 Ford Falcon Sprint 2007 Ford Mustang GT |
04-28-2021, 07:50 AM | #7 |
Used one in a GM distributor. Used the coil they said. Coil got so hot you couldn’t touch it. Contacted GMC buba. He told me to use a ballast resistor. Car was sold and still doing fine.
04-28-2021, 08:09 AM | #8 |
Ran Petronix in my 52 truck(12 vv-t) for 15 years and only had one "suspected" issue. Called them and the guy I spoke with helped me zero in on the real problem and all went well fo the next 14 years... Just like buying bananas some look good on the outside and then.... Chap
04-28-2021, 08:15 AM | #9 | |
I was never a fan of pertronix until I started getting bad condensers. Figure if I had to run questionable stuff go with something that does not need adjusting.
“The technique of infamy is to start two lies at once and get people arguing heatedly over which is true.” ~ Ezra Pound |
04-28-2021, 08:33 AM | #10 |
Re: chevy dists converted to 8BA....any customers who wish electronic ign over pts & cond I request they order the Pert and forward it to me so the warranty is in their name.
I strongly recommend the HALL effect version the reads the breaker cam lobes and not the unit that uses a relucter ring. I use the NAPA coil 12v IC 14 2.8 ohm. Charlie ny |
04-28-2021, 10:50 AM | #11 |
I stronfly suggest points especially if you want to use the stock coil. The Dwell period with a pertronix unit is about 50/50 on a helmet distributor.
I actually believe the reason they want you to use the ignitor coil (especially with 6 volt systems) I'd because of the dwell period. But as always I could be wrong but I had one unit fail and have gone back to points. Bob l |
04-28-2021, 10:57 AM | #12 |
Just wondering what are you guys running for plug wires?
04-28-2021, 11:23 AM | #13 |
everything was installed according to there tech department?? what else can I say!
04-28-2021, 11:42 AM | #14 |
04-28-2021, 11:55 AM | #15 |
With Pertronix ignition on an 8BA, 7mm Spiral wound wire to help prevent radio interference to the electronics as per Pertronix.
04-28-2021, 02:40 PM | #16 |
Pertronix has worked perfectly in every one of my cars for years. Pertronix conversions are used in the many vintage engines we run that have set numerous Land Speed Records.
Many customers have also had excellent success with the Pertronix conversions. HOWEVER the Pertronix unit will die if there's a short in the cars wiring. Its shocking your so unsuccessful with the conversion. Ronnieroadster
I use the F word a lot no not that word these words Flathead , Focus and Finish. "Life Member of the Bonneville 200 MPH Club using a Ford Flathead block" Owner , Builder, Driver of the First Ford Flathead bodied roadster to run 200 MPH Record July 13, 2018 LTA timing association 200.921 in one and a half miles burning gasoline. First ever gas burning Ford flathead powered roadster to run 200 MPH at Bonneville Salt Flats setting the record August 7th 2021 at 205.744 MPH |
04-28-2021, 06:19 PM | #17 |
Pertronix have the same reliability issues they had 30 years ago
when they were called PerLux. Solid state electronic stuff doesn't like intense searing heat, like what you find inside a distributor. Electronic devices like good grounds and you may not have good ones with a distributor. Those are my basic issues with Pertronix. To those that have had good fortune with their stuff I say good for you. My experience has not been that positive. |
04-28-2021, 07:15 PM | #18 |
No problems in three different cars. One is over 25 years old
04-28-2021, 07:57 PM | #19 |
Fried my Petronix while troubleshooting that turned out to be bad spiral wound ignition wires. I went back to points and copper ignition wires. Tubman condenser to insure against that crap shoot of reliability. The all copper wires setup completely jammed my satellite radio. Switched out the one foot coil to distributor high tension cable to spiral and got my radio back. Evidently it does not take much length of spiral wound to suppress the static. Runs great.
04-28-2021, 08:15 PM | #20 |
I had the same experience. Had ignition interference in the radio with all Packard 440. Replaced the coil wire with suppression wire and problem solved. You wouldn't think it would have made that much difference, but it did.
