Old 03-06-2021, 11:39 AM   #1
flathead4rd
flathead4rd's Avatar
Default 50 Ford heater control valve
My heater control valve has four 4 connections. My question is: Where does the hose from the water pump connect to and where does the hose from the cylinder head connect to? Thanks
flathead4rd is offline   Reply With Quote
Old 03-06-2021, 01:01 PM   #2
50fordcoupeman
50fordcoupeman's Avatar
Default Re: 50 Ford heater control valve
On my avatar, although not stock engine, the hose from the water pump connects to the top connection of the heater core. Hope this helps.
50fordcoupeman is offline   Reply With Quote
Old 03-06-2021, 01:17 PM   #3
flatford8
flatford8's Avatar
I believe it’s cyl. Head to bottom of temp control valve. Top of temp valve to bottom of heater core. Top of heater core back to fitting by water pump and it makes the trip again .... Mark
I'm thinkin' about crankin'
My ragged ol' truck up
and haulin' myself into town.
Billy Joe Shaver
Old 03-06-2021, 02:08 PM   #4
FortyNiner
FortyNiner's Avatar
This is the configuration for the I6, the same basic approach work for the V8. Top from the pump and bottom to the head.
