Old 01-07-2015, 11:57 PM   #21
Tom Wesenberg
Tom Wesenberg's Avatar
Default Re: Changing Differential Oil
Yep, that's what I used in the service station. Each time you had to turn the dial back to zero, then pump away. No guesswork as to how much was used.
Old 01-08-2015, 04:36 AM   #22
johnbuckley
johnbuckley's Avatar
I have modified a hand-pump pressure kit sold for killing garden weeds.
johnbuckley is offline   Reply With Quote
Old 01-09-2015, 07:05 PM   #23
whirnot
whirnot's Avatar
I use a transmission funnel witha flexible metal hose. I snake it up behind the body in front of the rear bumper and just pour it in. Takes a while but works good.
Bill Worden
1929 Roadster
1929 Briggs Town Sedan
1930 Closed Cab pickup
Smith Motor Compressor
1951 Ford F1
High Desert Model A's
whirnot is offline   Reply With Quote
Old 01-10-2015, 12:56 PM   #24
jwaldrich
jwaldrich's Avatar
Originally Posted by Tom Endy View Post
I use the 600W that Bratton's offer. It comes in a quart plastic squeeze bottle with a tapered cap. I usually buy several quarts at a time. I cut off the end of the tapered cap so there is about a 1\4" opening. With a full bottle it is easy enough to put your finger over the end of the cap point it into the banjo with the bottle held up at an angle. By squeezing the bottle it ports oil into the banjo. I fill to spill. When it begins to run out of the fill port, stop squeezing and allow it to run off to a drip.
With several bottles on hand it is easy enough to have a full bottle ready to go when there is need.
Tom Endy
Like Tom and others the squeeze bottle the 600W comes in was quick and easy to put in the pumpkin for me.
John from Kapowsin
T&A Guy
jwaldrich is offline   Reply With Quote
Old 01-10-2015, 03:01 PM   #25
mass A man
mass A man's Avatar
That's a great picture. I promise, I'm not laughing at all, really. I would never be so cruel. Excuse me now so I can wipe my eyes and catch my breath.
The good old squeeze bottle works fine for me.
mass A man is offline   Reply With Quote
Old 05-11-2015, 10:37 AM   #26
Cracker39
Cracker39's Avatar
Now I don't feel so bad. Apparently leaking differentials are just another way the Model A marks its' territory. I thought I had the leak licked when I found loose bolts on the driver's side of the banjo and torqued them down. Alas, that only slowed the leak.
Cracker39 is offline   Reply With Quote
Old 05-11-2015, 10:42 AM   #27
Mitch//pa
you think
Old 05-11-2015, 11:14 AM   #28
J Franklin
J Franklin's Avatar
I try to keep my head above the filler hole. I use a sta-lube pump that replaces the bottle cap.
Old 05-11-2015, 03:18 PM   #29
Dbbc
Dbbc's Avatar
Aloha,
I use a big syringe.
Dbbc is offline   Reply With Quote
Old 05-11-2015, 03:54 PM   #30
ian Simpson
Warm oil and a turkey baster.
Ian
ian Simpson is offline   Reply With Quote
Old 05-11-2015, 08:49 PM   #31
redmodelt
redmodelt's Avatar
I use the pump that came with some other rear end lube that I got for my truck. Fits on a plastic gallon paint thinner container. The pickup tube is spring loaded so it goes most of the way to the bottom. The long filler tube reaches the rear end, transmission the works on the steering box to.
Old 05-11-2015, 10:25 PM   #32
Y-Blockhead
Y-Blockhead's Avatar
Originally Posted by Bruce Adams View Post
Maybe this link to Harbor Freight will work.
http://www.homedepot.com/p/Plews-Suc...g&gclsrc=aw.ds
Nice tool, wrong place...
Old 05-11-2015, 11:39 PM   #33
pat in Santa Cruz
pat in Santa Cruz's Avatar
I use this....works like a charm
http://www.amazon.com/Lubrication-Ha.../dp/B0002SRJDQ
pat in Santa Cruz is offline   Reply With Quote
Old 05-12-2015, 01:16 AM   #34
Synchro909
Synchro909's Avatar
I took a funnel and cut the bottom off so I had a hole just the right size that I could push a 90 degree elbow from one of those plastic irrigation kits over the end of it. I then sealed it with some silicone (before it got oily). I put the end of the elbow into the filler hole and prop the funnel up so it stays upright. I fill it with oil and go away to do other stuff and come back later. By then, its all drained in so I refill and do more until the diff is full. Cheap and easy and gravity has no seals to fail. (It also never lets up!!!)
I'm part of the only ever generation with an analogue childhood and a digital adulthood.
