04-02-2019, 06:53 PM | #1 |
backfire.
What are some common causes of backfire?
04-02-2019, 07:00 PM | #2 |
Re: backfire.
Loud explosion backfire out of muffler/exhaust is caused by having a lot of unburned fuel collecting in the exhaust system.
This is usually because of faulty ignition. So the plugs are not firing (burning the fuel) and it goes into the exhaust. So look at: bad condenser, ignition points in bad condition, point gap too small, bad connectors from distributor cap to plugs, fouled plugs. An ignition switch going bad can do this, too. Or bad connections at the coil. HTH. .
04-02-2019, 10:08 PM | #3 |
Re: backfire.
Back firing is through the carburetor. After firing is through the exhaust.
04-03-2019, 07:08 AM | #4 |
Re: backfire.
I have never heard that term " After Firing".
04-03-2019, 07:29 AM | #5 |
Re: backfire.
Recently my 30 while on a outing was running fine and then started to bog down (no power) and backfire. Fuel starvation. Loosened gas cap, heard a tell tale "poof" sound. Fuel vent in gas cap was plugged. Replaced cap "loosely" and finished the trip. Used a small drill bit to clear the vent. Chap
04-03-2019, 01:39 PM | #6 | |
Re: backfire.
Could it have been an 'after fire'? |
04-03-2019, 07:40 AM | #7 |
Re: backfire.
I have a gas cap that we use with a small hole drilled in the very center of the cap.
One move potential problem solved. |
04-03-2019, 08:50 AM | #8 |
Re: backfire.
Leaky manifold gasket can do it.
04-03-2019, 11:06 AM | #9 |
Re: backfire.
04-03-2019, 01:37 PM | #10 |
Re: backfire.
The first sentence of that seems to say that it can also be called backfire.
04-03-2019, 01:59 PM | #11 |
Re: backfire.
Years ago when gasoline had lower octane and had less additives it was common for Model A's to need a valve job. The symptom was mild backfiring through the exhaust system when descending a long downhill grade with little acceleration from the accelerator needed. I've had this occur twice on long trips, once in 1947 and again in 1955. It was not unusual in those days and the old time mechanics knw the symptom and the repair needed. Needing the valves ground does not seem to be a problem now or in recent years.
04-03-2019, 04:28 PM | #12 |
Re: backfire.
Lot of screwy information.
Question: Does it cough out of the carbuerator air horn, or pop out of the tail pipe??? Bill W.
04-03-2019, 05:44 PM | #13 |
Re: backfire.
I recently got a car running and every time I let off on the gas, it would backfire. So I turned the GAV out a couple turns and no more backfiring. This carburetor is running lean. A too lean air fuel mixture for any reason will cause backfire, as stated above.
05-22-2019, 04:12 PM | #14 |
Re: backfire.
What is the GAV (I know I show my ignorance on this, but ...)?
04-03-2019, 05:51 PM | #15 |
Re: backfire.
I seen a bad condenser or a condenser on its way out causing a backfire
04-03-2019, 05:57 PM | #16 |
Re: backfire.
Yesterday got my truck back from a Model A shop, turned it off, and within a couple of seconds backfired through he exhaust. Got it running again at idle , GAV set full lean,advance lever up - was not running right. Got out and noticed black smoke out of the exhaust. Backed the idle mixture screw out a couple of turns until it started running better - issue solved.
Exhaust was loading up on unburned gas, and was ignited by the hot exhaust manifold. |
04-03-2019, 07:11 PM | #17 |
Re: backfire.
Float set too low on zenith carb. can cause back fire when gas petal is released. Lean mixture...
04-04-2019, 03:35 PM | #18 |
Re: backfire.
Have you all noticed that we got 1 question and 15 replies now and the Original Poster has not come back to clarify if he meant he was getting a true backfire out the intake throat of the carburetor or if he meant he was getting explosive backfire out of the tailpipe?
We have provided answers to both scenarios, but we still don't really know for sure what the symptoms are! Or perhaps he has solved the problem and never came back to tell us he found a loose wire, or replaced the condenser. And we are rambling on about float levels, leaky intakes, etc. No criticism to the people who have answered, I'm sure others appreciate reading the ideas. But as a courtesy to others, some follow up by the original poster would be nice. .
04-04-2019, 11:30 PM | #19 | |
Re: backfire.
04-05-2019, 12:29 AM | #20 |
Re: backfire.
Me: Doc, it hurts when i do THIS.
Doc: So quit doing THIS! .
