10-07-2019, 07:55 AM | #1 |
Replating Gear Shift Lever
I want to get two gesr shift levers replated but they are kind of rusty and I want to clean it. I don't think blasting is the best option.
"The more things change, the more they stay the same." |
10-07-2019, 08:08 AM | #2 |
Re: Replating Gear Shift Lever
Use a chemical rust remover such as Evapo-rust or Rust911 first. Then either remove the remaining plating electronically or let the plater do it. It is very easy to ruin a gear shift lever if it has much pitting, or needs much buffing. It is hard for them to keep the stick from becoming wavy.
10-09-2019, 08:13 PM | #3 |
I used a belt sander on my 2 levers before getting them nickel plated.
As Brent said, it's real easy to make them look wavy, so use lots of care. |
10-09-2019, 10:45 PM | #4 |
The bell shaped cover at the bottom has to fit the stick. If you grind too much off there it will flop around. A good platter can build up the pits with copper plate and grind it down.
10-10-2019, 05:55 AM | #5 |
Thread Tools | |
Display Modes | |
