06-30-2012, 07:43 PM | #21 |
Re: 30 ROADSTER -A hot rod in 1956 - Time for a refersh in 2012
Flop, Have you ever cut out the centers of Roadster rear fenders for use on late 1931 Pickups? Peter is shy and soft spoken so I'm asking for him. Bob.
They don't have to run to be enjoyed. I'm here to enjoy the hobby, and enjoy the cars no matter what they look like. Most of the worlds problems are electrical. |
06-30-2012, 07:58 PM | #22 |
The 2" section is not a particularly difficult job. If Flop doesn't have time to do them for you, I can.
1928 Model A Business Coupe Rebuild picture gallery here The light at the end of the tunnel has been turned off due to budget cuts. |
07-05-2012, 08:43 PM | #23 |
hey Peters ! sounds like a fun project if you have some roadster fenders that need sectioned down the middle! hell maybe ill even make a few sets if there is enough demand !!
more roadster action!! damn i love when parts fit together like they are supposed to !! rivets ready to be set hey look at that a roadster!!
Please call or email while website is down! 412 867 1659 [email protected] https://www.facebook.com/flop.custom Last edited by Flop; 07-10-2012 at 07:08 AM. |
07-07-2012, 06:33 AM | #24 |
Very nice!!!
07-08-2012, 11:13 AM | #25 |
Excellent progress, Tom -- keep it up!
07-08-2012, 12:42 PM | #26 |
i ended up buying a complete subframe from brookville already assembles best $460 i ever spent made in their jig with everything rivited and frame bolt holes already installed tk
anyone need some Model A restoration work done in Illinois? shoot me an email for pics and information [email protected] |
07-08-2012, 12:52 PM | #27 |
Hey Flop - Where did you get your subrails from?
07-08-2012, 09:53 PM | #28 |
I picked up the subrails from Snyder's (and supplied them to Flop when he picked up the rest of the body) right before I learned that Brookville sells the subrail assembly. I would have bought the assembly to save Flop some time. Live and learn. Besides, Tom is doing an amazing job with the loose rails.
07-09-2012, 08:10 PM | #29 |
Hey thanks Jeff!!
thanks roadster5040 didnt know they sold them put together . but it might kill ya on shipping if you couldnt pick them up at a model a parts house or swap meet. welllllll im a weirdo and wanted to start in a particular order. so i went and got the drivers side door and though hmmm this seems heavy. started grinding leaaad lead lead lead lead . got the torch out ... i think we need a new door skin .
Please call or email while website is down! 412 867 1659 [email protected] https://www.facebook.com/flop.custom Last edited by Flop; 08-01-2012 at 03:12 PM. |
07-09-2012, 08:59 PM | #30 |
That roadster must have belonged to a gangster .
A bullet proof drivers door who knew . Just what I was tole ,,,,,,,Pops |
07-09-2012, 09:58 PM | #31 |
Originally Posted by Flop
welllllll im a weirdo and wanted to start in a particular order. so i went and got the drivers side door and though hmmm this seems heavy. started grinding leaaad lead lead lead lead . got the torch out ... i think we need a new door skin . ----- I was hoping the doors would be more salvageable than that. yikes. |
07-10-2012, 07:23 AM | #32 |
Safety Tip for the rookies..........if you are grinding or sanding LEAD (not a good ideal) be sure to wear a good respirator. Better to use a hand file to shape or, as Flop did, use a tourch to melt/remove the lead off of the panel unless you are a pro body man.
07-10-2012, 07:37 PM | #33 |
I widened the rear fenders on a 1928 AA. First I made some marks across the flange and out across the fender with a square. Then I traced the bolt flange piece on 16 guage and cut two copies.
Next I cut each fender up against the flange to cut the old rusty flange off. I copied the marks I had made on the originals on the new pieces. Then I cut two 2" straps out of 18 guage the length of the fenders. Very carefully line up the marks with the strap between them and weld it up. If you are careful there won't be warpage. It was one of my first welds and just a skim coat was needed. Sorry, I didn't take pictures. |
07-11-2012, 07:55 AM | #34 |
only in a few spots hicktick!!
damn right richard . lead is no joke.use a vixen file to shape and a respirator to finish . luckily the passenger side didn't succumb to such a horrible fate .
Please call or email while website is down! 412 867 1659 [email protected] https://www.facebook.com/flop.custom Last edited by Flop; 07-11-2012 at 12:49 PM. |
07-23-2012, 07:47 PM | #35 |
well got a lot done on the cowl today . got the firewall spot welded in and got the cowl stripped and filled in some pin holes.got a few dents out as well
spot weld holes stripped down found some pinholes and old lead. welded up the pin holes and figured what the hell might as well fix up the old lead work and give the work i just did a light coat all finished up for today
Please call or email while website is down! 412 867 1659 [email protected] https://www.facebook.com/flop.custom Last edited by Flop; 08-01-2012 at 03:13 PM. |
07-23-2012, 07:58 PM | #36 |
Excellent work, Tom
07-25-2012, 07:32 AM | #37 |
getting there Jeff . You have once solid little roadster!!
such a solid car!! welded up 1 pin hole!! a taste of lead to fix the lead thats probably been there since 1956 and im happy with it!!
Please call or email while website is down! 412 867 1659 [email protected] https://www.facebook.com/flop.custom Last edited by Flop; 08-01-2012 at 03:14 PM. |
08-03-2012, 04:41 PM | #38 |
well got the hinges on ! this will probably be the last work for a while since i am moving shops at the end of next week . Time to start packing!!
Please call or email while website is down! 412 867 1659 [email protected] https://www.facebook.com/flop.custom Last edited by Flop; 08-03-2012 at 04:48 PM. |
08-05-2012, 05:59 PM | #39 |
Thanks for pics keep Them coming
08-05-2012, 07:23 PM | #40 |
You are one ambitious guy, Flop.
