Old 08-03-2020, 06:54 PM   #1
Licensed to kill
Licensed to kill's Avatar
Default Annoying rattle.
My car has an annoying rattle that occurs at slow speed but goes away at highway speed. It's a tinny sounding rattle that sounds like it's coming from under the dash or from the firewall. There really isn;'t anything under the dash or on/around the firewall that I can find that would make such a noise but there it is. I just had the motor/trans out for a rebuild and the did not find anything on the outside of the car or under the floor that would cause it which leads me back to under the dash but there is nothing there but the gas tank. Anyone experience such a rattle and find the source??
Licensed to kill is offline   Reply With Quote
Old 08-03-2020, 07:15 PM   #2
dpson
dpson's Avatar
Default Re: Annoying rattle.
I had a nasty sounding rattle when the car was first started that tended to diminish as the car was driven, except on rough roads. It was the windshield frame hitting the stanchion on the passenger side (1931 roadster). Push the windshield open and see if it goes away.
dpson is offline   Reply With Quote
Old 08-03-2020, 07:33 PM   #3
Dennisfly
Dennisfly's Avatar
I have a heat shield mounted on the exhaust over the muffler. The rear mount broke and it made a strange noise/resonance until I discovered and repaired it.
1929 Town Sedan (Briggs) 155B, Mitchell Overdrive
1935 Model 48 Tudor
Dennisfly is offline   Reply With Quote
Old 08-03-2020, 07:35 PM   #4
Synchro909
Synchro909's Avatar
Unhappy Re: Annoying rattle.
If everybody who has experienced a rattle in their Model A posts here, this thread will be the longest on the Forum!
Old 08-03-2020, 07:38 PM   #5
Al
Al's Avatar
I had a rattle that turned out to be the rod in E brake that is activated when you push the button on top to release the e brake. Drove me crazy till I found it as I thought it was dash/firewall/floorboard. Finally I just placed my finger on the button while driving , and no rattle Took it apart and covered with heat shrink tubing. Hope this helps you.
Al is offline   Reply With Quote
Old 08-03-2020, 07:54 PM   #6
Ruth
Bahahaha, that is exactly what I was thinking.
Ruth
Old 08-03-2020, 08:15 PM   #7
johnneilson
My shift knob does not rattle, so much for the rest of the car.............
J
As Carroll Smith wrote; All Failures are Human in Origin.
johnneilson is offline   Reply With Quote
Old 08-03-2020, 08:27 PM   #8
Digger
Digger's Avatar
My granddaughter has an annoying rattle too....I just go to the den.
Digger is offline   Reply With Quote
Old 08-03-2020, 08:34 PM   #9
Licensed to kill
It's not that. My car and my truck both have that one. This one is more tinny sounding.
Old 08-03-2020, 08:35 PM   #10
Licensed to kill
No heat shield on mine but the sound would match such a thing. thanks for the suggestion.
Old 08-03-2020, 08:36 PM   #11
Licensed to kill
I'll check that out. Thanks.
Old 08-03-2020, 09:04 PM   #12
Bill G
Bill G's Avatar
I had (sometimes have) a rattle from the clips that are riveted to the firewall that the hood supports go into. On one of mine, the rivets have really loosened up and I have to compensate by tightening the hood support rod just right. One of these days I will grind off the rivets and use the rivet-head screws the vendors sell, but it drove me nuts until I found it. Maybe that is your rattle.
Old 08-03-2020, 09:28 PM   #13
chrs1961815
chrs1961815's Avatar
Check for loose rivets and loose bolts/nuts.
"The more things change, the more they stay the same."
chrs1961815 is offline   Reply With Quote
Old 08-04-2020, 08:47 AM   #14
Bob Bidonde
Bob Bidonde's Avatar
This sneaky rattle is hard to find and very annoying.
Bob Bidonde
Old 08-04-2020, 08:58 AM   #15
ArtimusGordon
A club member once told if I hear strange noises coming from my Model A to just “TURN UP THE RADIO “. ��
ArtimusGordon is offline   Reply With Quote
Old 08-04-2020, 09:22 AM   #16
1928Mik
1928Mik's Avatar
Yeah, I have a strange rattle towards the front of the car right now. Sounds like a loose hose clamp or something similar. At idle or driving, rattle is there. Everything is greased. I have no idea at the moment!
1928 Niagara Blue Phaeton
1972 Olds 442 Convertible
1979 MGB
-Life's Too Short To Drive Boring Cars-
1928Mik is offline   Reply With Quote
Old 08-04-2020, 09:45 AM   #17
oldbird55
could be the advance & throttle rods in the steering columm mine do that.
oldbird55 is offline   Reply With Quote
Old 08-04-2020, 09:49 AM   #18
Will N
Will N's Avatar
If you have engine pans, take a look at where they mount to the oil pan. I once found that one of the ears had cracked from the vibrations, and it caused a rattle.
Will N is offline   Reply With Quote
Old 08-04-2020, 10:12 AM   #19
Perry
the flame arrestor in my gas tank works loose and rattles. sounds like it is under the dash.
Perry is offline   Reply With Quote
Old 08-04-2020, 10:57 AM   #20
Jacksonlll
Jacksonlll's Avatar
Reach way under the dash and make sure those clamps that mount the gas tank are tight.
