02-18-2013, 01:12 PM | #61 |
Re: Zinc been taken out of Rotella oil & other diesel brands
If it were mine, I would be comfortable with dropping the pan and cleaning it and the pic up screen out. Follow up with 20W/50 detergent and don't worry about it. You won't get big loose particles breaking loose and floating around. Done it MANY times with no ill effects.
02-18-2013, 02:30 PM | #62 |
I use Valvoline racing 20-50 oil available at NAPA.It has zinc in it.What happens without the zinc the cam can go flat.
02-18-2013, 06:27 PM | #63 |
As has been stated many times, there is still zinc in the oil, just not as much. Still plenty for any flathead. Use your favorite oil and sleep easy.
04-09-2013, 11:34 AM | #64 |
For what it's worth.....I had to go to Auto Zone for something this morning and ran across a can of STP Oil Additive.....on the label it said it had a zinc additive in it !
I asked the guy in the store and he said yes it did, as well as a Valvoline Oil he showed to me. Mike |
04-09-2013, 01:23 PM | #65 | |
04-09-2013, 02:31 PM | #66 |
04-09-2013, 08:39 PM | #67 |
Why such heavy oils? Ron says 5-20. Which is much lighter. I drive a old turbo diesel... use rotella. Just a matter of opinion?
04-10-2013, 07:23 AM | #68 |
Here is the follow up on the engine we put new valve train parts in and drove around 1,000 miles without any zinc additive last fall. The engine valve train was very noisy after the 1,000 miles so we adjusted the valves again and added Lucas Zinc additive to the Rotella oil. He showed up this week end with 628 miles on the new engine valve adjustment and the Lucas Zinc additive with NO valve train noise. Did the zinc prevent the valve train noise from returning or was that need for a valve train adjustment just the natural break in wear for new engine parts???? For the cost of the zinc additive I think I will add the zinc additive to my oil changes. Can not be too pretty, too rich, or have to much engine protection in my thinking.
04-10-2013, 11:29 AM | #69 |
I never thought of using stythetic oil.Any votes for or against?
04-10-2013, 01:18 PM | #70 |
I want the best oil for my FH, when I bought it in mid '90s it ran good but no history of a rebuild etc. just that I should continue to use 40 non-detergent oil. Reading all the comments here I got ready to order CCMO. Went to their site & in the info they stated "if using non-detergent oil, CCCMO is not recommended" . The engine was clean inside the valley cover & oil pan had no sludge. The engine has been running good since on the road 9/2009 with 2 non/D oil changes with Zinc & MMO added & 378 miles run time. Im a member of the "Leave well enough alone Club" So untill my fear subsides ???
