10-05-2019, 11:47 PM | #1 |
Front Wheel Cylinders
I have found significant pitting in my 1939-41 front wheel cylinders (1"" / 1.25"). These are evidently no longer available from the vendors, who suggest changing to the 1942-48 wheel cylinders (1" / 1.375"). Any thoughts regarding this change regarding pedal effort, braking efficiency, etc. ? Thanks much!
10-06-2019, 12:03 AM | #2 |
Re: Front Wheel Cylinders
Might be a good time to convert to the Bendix style (Lincoln) brakes. Complete bolt-on kits are available.
10-06-2019, 01:11 AM | #3 |
Later wheel cylinders work; been using them for replacements for quite a while.
Note that the Chinese seem to have a problem getting the holes drilled right, been milling the slot deeper in the big piston to let the cup sit out farther and clear the misplaced hole. |
10-06-2019, 11:31 AM | #4 | |
Is there an alternative source to the product from China? |
10-06-2019, 11:59 AM | #5 |
Try Rock Auto. Look for 1946 Ford. Also your local NAPA may be able to get you these parts which are not made in China.
10-06-2019, 12:56 PM | #6 |
10-06-2019, 01:17 PM | #7 |
On my 47, I found that someone had previously installed new, earlier 1-1/4 cylinders. I changed back to 1-3/8 on my 47. So, I have 'near-new' 1-1/4 cylinders, which I will offer free. Of course, if you were seeking my advise, I would suggest using new, 1-3/8 cylinders for your application. Improved braking, meaning less pedal force needed. (Ford thought this up, not me.)
