10-05-2019, 12:15 PM | #21 |
Re: Ballast resistor getting real hot
Thanks Bubba!
10-05-2019, 12:54 PM | #22 | |
10-05-2019, 12:58 PM | #23 |
The stock ballast resistor is calibrated for six volts. When converting to 12 volts you can remove the resistor from the circuit by replacing the coil with one rewound for the higher voltage. Skip Haney does it for us. The stock 6 volt resistor is wound with nichrome wire, also used in old toasters and gets very hot as engine speed increases, to act as a voltage regulator to protect the ignition system.
