09-05-2019, 09:53 PM | #1 |
Compressor oil
What type of oil is used in a 30 year old single stage compressor ???
09-05-2019, 10:39 PM | #2 |
Re: Compressor oil
Most small air compressors use SAE 30 non-detergent oil. Special compressor oil is available. However, the old Sears vertical fin compressors recommended 10W-30 with API SF designation, but I would not use the current multi-grade oils.
09-06-2019, 07:12 PM | #3 |
Re: Compressor oil
30 weight non detergent.
09-07-2019, 10:13 AM | #4 |
Re: Compressor oil
Compressor oil is a bit more expensive since it is much more highly refined in order to take the pressures involved. I always get compressor oil but then my compressor is a big one. I change the oil once a year whether it needs it or not.
09-07-2019, 12:36 PM | #5 |
Re: Compressor oil
Made the oil seem like a good buy. So I would recommend compressor oil. John
Welcome each day |
