Old 05-05-2013, 02:45 PM   #1
Al K.
Al K.'s Avatar
Default 34 p/u grill
Hi,
Actually two questions, first, Is the small hole in the top of the shroud right below the radiator fill hole supposed to be round or some other shape. See the picture. Second, are all four radiator to shroud brackets identical. I only have one but can make more if they are the same. Thanks, Al K.
Al K. is offline   Reply With Quote
Old 05-05-2013, 03:26 PM   #2
FlatheadTed
FlatheadTed's Avatar
Default Re: 34 P/U shroud
The hole in the top of the shell is a stamped horse shoe shape with a 3/16 hole in the bottom. The brackets are not matched there is one for the top and one for the bottom are,
http://www.flatheadted.com
Flathead Ted brake Floaters ,
Old 05-05-2013, 04:48 PM   #3
Lawson Cox
Lawson Cox's Avatar
What you are referring to is more correctly called a grill. A shroud generally applies to a metal piece that fits on the back side of the radiator and has a large hole in the center, the same size of the fan blade, the purpose being to direct all of the air the fan pulls through the radiator is directed to the center of the radiator for optimum air flow and cooling. I do not believe a shroud would be original equipment for a 34 Ford.
Old 05-06-2013, 06:57 AM   #4
31chevy
31chevy's Avatar
Default Re: 34 p/u grill
Flatheadted is correct the upper & lower are different as to the other ? here is a picture of the finished shell.
31chevy is offline   Reply With Quote
Old 05-06-2013, 12:22 PM   #5
Al K.
Al K.'s Avatar
Thank you for all the replies and corrections, wink. I would assume then that the hole that I am concerned about has some sort of fastening device in it to secure the emblem.
Can someone provide a sketch or measurements for the upper bracket?
Thanks, Al K
Old 05-06-2013, 01:08 PM   #6
2ndgeer
2ndgeer's Avatar
The mounting brackets for the 1933-34 Ford pickup (commercial) grille shell have been reproduced. The set of hardware is available from many parts suppliers. Just Google 1934 Ford pickup grille and look in images. You'll see them.
2ndgeer is offline   Reply With Quote
Old 05-06-2013, 04:45 PM   #7
FlatheadTed
A screw goes through into the radiator ,check a emblem
Thanks, Al K
Old 05-06-2013, 06:02 PM   #8
Al K.
Al K.'s Avatar
Thanks for the tips. Will search for them.
Thanks for the screw info. Not having the emblem yet made it difficult to picture why the hole was there.
Al K.
