Old 05-31-2021, 09:40 PM   #1
Visiblepump
Default Fan Blade Concern
The 29 Tudor my Brother in Law is rebuilding has a fan blade on it that I have not seen before. It runs smoothly but is not one piece. The two blades are fastened to the central hub but no welds are readily evident. You can see the line in the photo where the blade is attached to the hub. It appears rather professionally done. Is anyone familiar with a blade like this. Should he trust it?
Visiblepump is offline   Reply With Quote
Old 05-31-2021, 09:49 PM   #2
goodcar
Default Re: Fan Blade Concern
Hard to tell from the picture what you have. If there is any doubt at all about the condition of this fan, I would replace it. Not worth the trouble and expense if it comes apart taking out the radiator and hood.
goodcar is offline   Reply With Quote
Old 05-31-2021, 09:53 PM   #3
Mike Peters
Mike Peters's Avatar
Looks like an original two blade fan with a crack. Don't run the engine before replacing. It could let go any time. I'm serious. These old original fans can be very dangerous. Don't run the engine with that fan!
Mike Peters is offline   Reply With Quote
Old 05-31-2021, 10:02 PM   #4
goodcar
I agree, this could be even worse than the radiator and hood that I previously mentioned. A few years ago, a guy in Iowa was standing by his running Chevy S10 when the fan came apart. He is no longer with us.
Old 05-31-2021, 10:06 PM   #5
Bob C
Yep looks like an original fan that will soon look like the one in the picture.
Old 05-31-2021, 10:55 PM   #6
CWPASADENA
CWPASADENA's Avatar
I believe what you have is one of the later production Ford 2 blade fans. These came out in March of '31. Unlike the original design 2 blade fan where the complete blade was 2 thicknesses of steel, this fan had 2 thicknesses of steel in just the part of the blade adjacent to the hub and the rest of the blade was a single thickness.
Now that said, I would highly recommend you replace it. Both design fans were prone to failure.
Chris W.
CWPASADENA is offline   Reply With Quote
Old 05-31-2021, 11:09 PM   #7
700rpm
700rpm's Avatar
Just replace it. Cheap insurance against a very risky and consequential failure.
Ray Horton, Portland, OR
Old 06-01-2021, 04:59 AM   #8
Stingray70
Stingray70's Avatar
Are you guys sure that isn't a modern cast aluminum fan? That line looks like the casting mark on mine. A clearer picture would help. OP may want to see if the fan blade is magnetic?
1930 Standard Coupe
Stingray70 is offline   Reply With Quote
Old 06-01-2021, 07:19 AM   #9
marty in Ohio
marty in Ohio's Avatar
I would echo Stingray's post. Put a magnet on the fan. If it sticks, replace it, if the magnet falls off, drive it.
Marty
marty in Ohio is offline   Reply With Quote
Old 06-01-2021, 11:48 AM   #10
old31
Even if a magnet fell off, I would not drive it with that fan.
Old 06-01-2021, 12:10 PM   #11
Bob Bidonde
Bob Bidonde's Avatar
Ford knew about fan blade failures, so the design of the fan blade was changed to a single thickness. However, the change did not work. No original fan is safe to use regardless of how well it looks, and regardless of how it is repaired / strengthened. The amount of fatigue life expended on an original fan is unknown, so all are liable to throw a blade at any moment.
Bob Bidonde
Old 06-01-2021, 03:28 PM   #12
hazelhoff
hazelhoff's Avatar
Actually some after market steel fans did exist. I happen to have one. They are made of two full single blades, twisted and welled along the edges. Look like the originals ! Mine should be safe, had it X-rayed for crack detection.
You don’t own a Model A ... it owns you !
hazelhoff is offline   Reply With Quote
Old 06-02-2021, 05:29 PM   #13
GRutter
GRutter's Avatar
That's a late 31 fan. Used thru model B production as well. Much stronger hub design that the original fan. Look at the hub - no seams, no welded overlap. If it concerns you, replace it. I personally have no concerns with the late 31 design.
GRutter is offline   Reply With Quote
Old 06-02-2021, 08:07 PM   #14
Gene F
Gene F's Avatar
I drive my car, so I changed to the 8 blade plastic one on an aluminum hub that Snyders sells.
Gene F is offline   Reply With Quote
