12-29-2020, 02:45 PM | #1 |
1929 Tudor lower firewall holes
My brother-in-law is restoring a 1929 Tudor. He does the physical work and I agreed to help him on researching. I have some question regarding holes in the lower firewall. I know some are supposed to be there and others have probably been added by previous owners.
Which ones will he need to patched up? 1. I assume holes in circles in 1, 3 & 4 should be patched. Does anyone know why the holes would have been added inside circle #1? I assume the holes in circle # 3 & 4 were for a heater core, but not original. 2. The holes in circle # 2, 5 & 6 appear to be original, if so what were the used for? Thank you for your knowledge! |
12-29-2020, 03:14 PM | #2 |
Re: 1929 Tudor lower firewall holes
I believe numbers 2&6 are for the studs for the carpet. Numbers 1,3,4,& 5 are extra holes to be filled.
12-29-2020, 03:48 PM | #3 |
Let's keep #5 to use for the speedometer cable clamp. You are correct on the others.
Last edited by BRENT in 10-uh-C; 12-29-2020 at 04:09 PM. Reason: Add picture for clarification. |
12-29-2020, 03:53 PM | #4 |
3 and 4 were probably heater hose holes.
I still have an excellent rememberer, trouble is my forgetter is so much better that it often overrides the rememberer. |
12-29-2020, 05:23 PM | #5 |
Thank you for your speedy answers. I appreciate your help.
12-29-2020, 07:51 PM | #6 |
