08-11-2020, 02:33 PM | #1 |
Name that Block
Some help please in block identification, thanks!
08-11-2020, 02:40 PM | #2 |
Re: Name that Block
With my limited flathead experience and only one picture, I can't tell other than I think they are 21 stud blocks with block mouthed water pumps, which I think puts them from '36 to early '38 ? Just a guess.
Sal |
08-11-2020, 02:48 PM | #3 |
Re: Name that Block
08-11-2020, 02:52 PM | #4 |
Re: Name that Block
Crummy pictures. At least count the studs required and the width of the main cap studs. And show if a full bellhousing is required over the flywheel.
08-11-2020, 02:53 PM | #5 |
Re: Name that Block
It's the only pic I have. I'm trying to figure out on the 2nd one what the pieces are that are mounted on either side. And what castings had pipe plugs on the jackets.
08-11-2020, 02:55 PM | #6 |
Re: Name that Block
Or put it another way, they are not our "normal" v8 type of any configuration. Edit: I just googled v8-60 and they look like the pics above. |
08-11-2020, 03:19 PM | #7 |
Re: Name that Block
They ARE V8-60s. This pic shows the exhaust port studs in a vertical, rather than slanted configuration. You can also see the coolant hose exiting the side of block. DD
08-11-2020, 04:02 PM | #8 |
Re: Name that Block
Interesting "Harley" ;-)
08-11-2020, 04:14 PM | #9 |
Re: Name that Block
08-11-2020, 04:17 PM | #10 |
Re: Name that Block
That ain't no Harley...it's now a "Ford-ley"! |
08-11-2020, 04:44 PM | #11 |
Re: Name that Block
All V8/60 blocks as stated.
08-11-2020, 06:09 PM | #12 |
Re: Name that Block
3 tin sided and one cast?
