02-25-2021, 11:26 AM | #1 |
2nd appeal for modern Rubelite Red Paint code
While my previous request for Rubelite Red paint code got a lot of responses (for which I am appreciative), I never got an actual code.
The local paint shops were not able to use Dupont code - RS536 to come up with anything in modern base coat color. If anyone has a modern code I would appreciate you sharing it with me. Thank You. |
02-25-2021, 11:34 AM | #2 | |
Re: 2nd appeal for modern Rubelite Red Paint code
02-25-2021, 11:51 AM | #3 | |
Probably because most restorers don't use base-clear when they are restoring. DuPont is no longer in the paint business either, which is why they likely could not cross-reference it. How I would approach something like this is to find a PPG jobber store. Have them call the PPG library and obtain the formula for their DBU line. If you do not wish to go that way, find a paint jobber that has a spectrophotometer where they can scan the chip in the Model-A Ford Paint & Refinish guide and mix from there. |
02-25-2021, 12:07 PM | #4 | |
02-25-2021, 06:20 PM | #5 |
For my maroon 1930 Fordor I cut out a portion of the chip from the Model-A Ford Paint & Refinish guide and sent it off to https://tcpglobal.com/. They charged me $60 to color match the chip and $129.96 for a quart of acrylic enamel. A quart will last a long time as I am only going to use it for touchup. I have not received the paint yet, it gets shipped across the country by Ox cart. The chip was a little lighter than the paint on my car so if it does not quite match I will add some black which I already have.
02-25-2021, 06:46 PM | #6 |
02-25-2021, 07:27 PM | #7 |
My CCPU is painted with single stage NASON PAINT RUBELITE RED. PAINT CODE CG 596 1FG.
It’s the same code for the basecoat clearcoat. My body man/painter has used NASON paint for 25 years on Model A’s and other Classic cars and swears by it. It’s been 5 years since it was painted. I have had zero issue with it and am totally satisfied with its durability. Last edited by GPierce; 02-25-2021 at 08:06 PM. |
02-26-2021, 11:21 AM | #8 |
That’s a nice looking truck. [emoji106]
Sent from my iPhone using Tapatalk |
03-02-2021, 02:41 PM | #9 |
We went to the local paint jobber and gave him the paint code CG 596 1FG. We told him it was a Nason paint code. He came up with nothing. He even contacted the regional office and they said the number doesn't show up in any of their computers or books.
Am I missing something? Is there another bit of information that was missing that I should know? Thank you. |
03-02-2021, 02:45 PM | #10 |
Have you had it scanned?
03-02-2021, 02:55 PM | #11 |
Check your "Private Messages" in the top right corner of this webpage.
Marshall |
03-02-2021, 05:17 PM | #12 | |
The paint code was from the local NASON paint distributor who scanned the chip. My painter has mix code. |
03-04-2021, 08:33 AM | #13 |
You should visit TCP Global web site. I was able to find Rubelite Red paint from that supplier. Available in any type you wish.
03-04-2021, 09:50 AM | #14 |
Can you post a link to TCP Global Showing that? All I could find was Mercedes Rubelite red on TCP’s web site. Not sure that is the same as the Ford Rubelite Red.
03-04-2021, 10:37 AM | #15 |
I have the numbers for OMNI,taken off the label on the can.It says,brand code,3954.OEM code,7DNAXXA,EM,M6153A,MX7071034.Ford North America,48 Ford commercial red-rubelite red.When I had it mixed the paint guy said,hey,this translates into a Model A color too,Rubelite red.He also told me the it is probably not really either color exactly,but close to both.This paint was mixed,12-23-2001.I was looking for a subdued red in the fleet color chart,and liked the 48 Ford commercial red.I don't agonize over color,I can pretty much throw a dart at a chip chart and be happy.
