10-31-2020, 07:57 PM | #1 |
Horn
I'll get the horn working and after the couple months driving around Town--
it slowly will only chirp. Do they require that much attention, or what. It's not a Model A if the horn don't work right -- and yes, it's been rebuilted/oiled. |
10-31-2020, 10:03 PM | #2 |
Re: Horn
Your generator needs to be charging to get a good horn sound. Otherwise, loosen the adjuster screw one or two clicks on the back of your horn and see if that helps.
11-01-2020, 06:10 AM | #3 |
Re: Horn
Guten Morgen,
it is also important that the copper collector and the motor brushes are free of grease and smooth.
Beste Gruesse aus Deutschland, Werner Ford Model A, Roadster, 1928 Citroen 11 CV, 1947 Hercules W 2000, 1976; (with NSU-Wankel Rotary Engine), Canadian version |
11-01-2020, 06:11 AM | #4 |
Re: Horn
I use sewing machine oil to oil my horn. The outside temperature plays a part in the horn efficiency. If I know I'm going to be using it: I back off the screw, press the button and spin the motor to warm up and thin the oil. I then retune it by adjusting the screw.
http://MODELABASICS.com/ How Things Work on a Model "A" Ford Fordbarners, Feel free to use the pictures on my site to answer questions and create tutorials/tech articles. |
11-01-2020, 06:18 AM | #5 |
Re: Horn
My horn has stopped working, all of the above suggestions have been accomplished. In the dark I noticed occasional small sparks behind the horn button when pushed and a slight sound from the horn. Suggestions?
John |
11-01-2020, 11:24 AM | #6 |
Re: Horn
11-03-2020, 05:46 PM | #7 |
Re: Horn
If you mean, by horn button, the button in the middle of the steering wheel, sounds like it’s rusty, or corroded underneath there. I have just held the horn button down, and rotated it with the palm of my hand to try and clean it, which helped. I am not sure how you could see sparks from there though?
11-03-2020, 06:52 PM | #8 |
Re: Horn
On my A, I added a ground wire for all six of the lights, the horn, and finally the engine to the frame. Grounds or lack there of, can be real gremlins.
11-03-2020, 08:45 PM | #9 |
Re: Horn
